| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System RIPng Administration Guide |
Configuring the RIPng Topology Example
Enable and Configure RIPng on Desired IPv6 Interfaces
Disable the split-horizon Option
Use the following commands to configure VLAN 50 and VLAN 40 on switch SEFOS1 in the example topology.
SEFOS 1 SEFOS# configure terminal SEFOS 1 SEFOS(config)# set gvrp disable SEFOS 1 SEFOS(config)# set gmrp disable SEFOS 1 SEFOS(config)# interface extreme-ethernet 0/15 SEFOS 1 SEFOS(config-if)# switchport access vlan 50 % Access VLAN does not exist.,Creating vlan SEFOS 1 SEFOS(config-if)# exit SEFOS 1 SEFOS(config)# interface vlan 50 SEFOS 1 SEFOS(config-if)# no shutdowndown SEFOS 1 SEFOS(config-if)# ipv6 enable SEFOS 1 SEFOS(config-if)# ipv6 address 5555::14 112 SEFOS 1 SEFOS(config-if)# exit SEFOS 1 SEFOS(config)# vlan 40 SEFOS 1 SEFOS(config-vlan)# port extreme-ethernet 0/3 SEFOS 1 SEFOS(config-vlan)# exit SEFOS 1 SEFOS(config)# interface extreme-ethernet 0/3 SEFOS 1 SEFOS(config-if)# no shut SEFOS 1 SEFOS(config-if)# exit SEFOS 1 SEFOS(config)# interface vlan 40 SEFOS 1 SEFOS(config-if)# no shut SEFOS 1 SEFOS(config-if)# ipv6 enable SEFOS 1 SEFOS(config-if)# ipv6 address 4444::14 112 SEFOS 1 SEFOS(config-if)# end SEFOS 1 SEFOS# configure terminal SEFOS 1 SEFOS(config)# vlan 30 SEFOS 1 SEFOS(config-vlan)# port extreme-ethernet 0/7 SEFOS 1 SEFOS(config-vlan)# exit SEFOS 1 SEFOS(config)# interface extreme-ethernet 0/7 SEFOS 1 SEFOS(config-if)# no shut SEFOS 1 SEFOS(config-if)# exit SEFOS 1 SEFOS(config)# interface vlan 30 SEFOS 1 SEFOS(config-if)# no shut SEFOS 1 SEFOS(config-if)# ipv6 enable SEFOS 1 SEFOS(config-if)# ipv6 address 3333::14 112 SEFOS 1 SEFOS(config-if)# end SEFOS 1 SEFOS#
SEFOS 1 SEFOS# show ipv6 interface
vlan1 is up, line protocol is up
IPv6 is Enabled
Link local address:
fe80::221:28ff:fe56:d7a9
Global unicast address(es):
Not Configured.
Joined group address(es):
ff02::1
ff02::2
ff02::1:ff56:d7a9
MTU is 9216
ICMP redirects are enabled
ND DAD is enabled, Number of DAD attempts: 1
ND router advertisement is disabled
vlan50 is up, line protocol is up
IPv6 is Enabled
Link local address:
5555::14/112
ff02::1
ff02::2
ff02::1:ff00:14
ff02::1:ff56:d7a9
MTU is 9216
vlan40 is up, line protocol is up
IPv6 is Enabled
Link local address:
4444::14/112
ff02::1
ff02::2
ff02::1:ff00:14
ff02::1:ff56:d7a9
MTU is 9216
vlan30 is up, line protocol is up
IPv6 is Enabled
Link local address:
3333::14/112
ff02::1
ff02::2
ff02::1:ff00:14
ff02::1:ff56:d7a9
MTU is 9216
