| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System RIPng Administration Guide |
Configuring the RIPng Topology Example
Enable and Configure RIPng on Desired IPv6 Interfaces
Disable the split-horizon Option
Configure VLAN 10 and VLAN 40 interfaces on SEFOS2 in the example topology.
SEFOS 2 SEFOS# configure terminal SEFOS 2 SEFOS(config)# set gvrp disable SEFOS 2 SEFOS(config)# set gmrp disable SEFOS 2 SEFOS(config)# interface extreme-ethernet 0/15 SEFOS 2 SEFOS(config-if)# switchport access vlan 10 % Access VLAN does not exist.,Creating vlan SEFOS 2 SEFOS(config-if)# exit SEFOS 2 SEFOS(config)# interface vlan 10 SEFOS 2 SEFOS(config-if)# no shut SEFOS 2 SEFOS(config-if)# ipv6 enable SEFOS 2 SEFOS(config-if)# ipv6 address 1111::12 112 SEFOS 2 SEFOS(config-if)# exit SEFOS 2 SEFOS(config)# interface vlan 40 SEFOS 2 SEFOS(config-if)# no shut SEFOS 2 SEFOS(config-if)# ipv6 enable SEFOS 2 SEFOS(config-if)# ipv6 address 4444::12 112 SEFOS 2 SEFOS(config-if)# exit SEFOS 2 SEFOS(config)# vlan 40 SEFOS 2 SEFOS(config-vlan)# ports extreme-ethernet 0/3 SEFOS 2 SEFOS(config-vlan)# exit SEFOS 2 SEFOS(config)# interface extreme-ethernet 0/3 SEFOS 2 SEFOS(config-if)# no shut SEFOS 2 SEFOS(config-if)# end
SEFOS 2 SEFOS# show ipv6 interface
vlan1 is up, line protocol is up
IPv6 is Enabled
Link local address:
fe80::214:4fff:fe6c:630f
Global unicast address(es):
Not Configured.
Joined group address(es):
ff02::1
ff02::2
ff02::1:ff6c:630f
MTU is 9216
ICMP redirects are enabled
ND DAD is enabled, Number of DAD attempts: 1
ND router advertisement is disabled
vlan40 is up, line protocol is up
IPv6 is Enabled
Link local address:
4444::12/112
ff02::1
ff02::2
ff02::9
ff02::1:ff00:12
ff02::1:ff6c:630f
MTU is 9216
vlan10 is up, line protocol is up
IPv6 is Enabled
Link local address:
1111::12/112
6666::12/112
ff02::1
ff02::2
ff02::9
ff02::1:ff00:12
ff02::1:ff6c:630f
MTU is 9216
