| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System RIPng Administration Guide |
Configuring the RIPng Topology Example
Disable the split-horizon Option
SEFOS 1 SEFOS# configure terminal SEFOS 1 SEFOS(config)# interface vlan 30 SEFOS 1 SEFOS(config-if)# ipv6 rip enable SEFOS 1 SEFOS(config-if)# exit SEFOS 1 SEFOS(config)# interface vlan 40 SEFOS 1 SEFOS(config-if)# ipv6 rip enable SEFOS 1 SEFOS(config-if)# exit SEFOS 1 SEFOS(config)# interface vlan 50 SEFOS 1 SEFOS(config-if)# ipv6 rip enable SEFOS 1 SEFOS(config-if)#
SEFOS 2 SEFOS# configure terminal SEFOS 2 SEFOS(config)# interface vlan 10 SEFOS 2 SEFOS(config-if)# ipv6 rip enable SEFOS 2 SEFOS(config-if)# exit SEFOS 2 SEFOS(config)# interface vlan 40 SEFOS 2 SEFOS(config-if)# ipv6 rip enable SEFOS 2 SEFOS(config-if)# exit
SEFOS 3 SEFOS# configure terminal SEFOS 3 SEFOS(config)# interface vlan 20 SEFOS 3 SEFOS(config-if)# ipv6 rip enable SEFOS 3 SEFOS(config-if)# exit SEFOS 3 SEFOS(config)# interface vlan 30 SEFOS 3 SEFOS(config-if)# ipv6 rip enable SEFOS 3 SEFOS(config-if)# exit
SEFOS 1 SEFOS# show ipv6 rip RIP port 521, multicast-group ff02::9,Maximum paths is 16 Updates every 30 seconds; expire after 180SEFOS 1 SEFOS# show ipv6 rip database Garbage Collect after 120 secondsRIP local RIB 1111::/112, metric 2, ripng vlan40/fe80::214:4fff:fe6c:630f, expires in 180 secs 2222::/112, metric 2, ripng vlan30/fe80::214:4fff:fe6c:686d, expires in 180 secs 3333::/112, metric 2, ripng vlan30/fe80::214:4fff:fe6c:686d, expires in 180 secs 3333::/112, metric 1, local vlan30/::, expires in 180 secs 4444::/112, metric 2, ripng vlan40/fe80::214:4fff:fe6c:630f, expires in 180 secs 4444::/112, metric 1, local vlan40/::, expires in 180 secs 5555::/112, metric 1, local vlan50/::, expires in 180 secs 6666::/112, metric 2, ripng vlan40/fe80::214:4fff:fe6c:630f, expires in 180 secs Poison Reverse is on Interface: vlan50 vlan40 vlan30 Redistribution: Connected,Routes Redistribution is enabled.
SEFOS 1 SEFOS# show ipv6 route IPv6 Routing Table - 8 entries Codes : C - Connected, S - StaticSEFOS 1 SEFOS# show ipv6 route summary O - OSPF, R - RIP, B - BGPIPv6 Routing Table Summary - 8 entries 3 Connected, 0 Static, 5 RIP, 0 BGP, 0 OSPF Number of prefixes: /112: 8 R 1111::/112 [2/120] via fe80::214:4fff:fe6c:630f, vlan40 R 2222::/112 [2/120] via fe80::214:4fff:fe6c:686d, vlan30 C 3333::/112 [1/1] via ::, vlan30 R 3333::/112 [2/120] via fe80::214:4fff:fe6c:686d, vlan30 C 4444::/112 [1/1] via ::, vlan40 R 4444::/112 [2/120] via fe80::214:4fff:fe6c:630f, vlan40 C 5555::/112 [1/1] via ::, vlan50 R 6666::/112 [2/120] via fe80::214:4fff:fe6c:630f, vlan40
SEFOS 2 SEFOS# show ipv6 rip RIP port 521, multicast-group ff02::9,Maximum paths is 16 Updates every 30 seconds; expire after 180SEFOS 2 SEFOS# show ipv6 rip database Garbage Collect after 120 secondsRIP local RIB 1111::/112, metric 1, local vlan10/::, expires in 180 secs 2222::/112, metric 3, ripng vlan40/fe80::221:28ff:fe56:d7a9, expires in 180 secs 3333::/112, metric 2, ripng vlan40/fe80::221:28ff:fe56:d7a9, expires in 180 secs 4444::/112, metric 1, local vlan40/::, expires in 180 secs 5555::/112, metric 2, ripng vlan40/fe80::221:28ff:fe56:d7a9, expires in 180 secs 6666::/112, metric 1, local vlan10/::, expires in 180 secs Poison Reverse is on Interface: vlan40 vlan10 Redistribution: Connected,Routes Redistribution is enabled.
SEFOS 2 SEFOS# show ipv6 route IPv6 Routing Table - 6 entries Codes : C - Connected, S - StaticSEFOS 2 SEFOS# show ipv6 route summary O - OSPF, R - RIP, B - BGPIPv6 Routing Table Summary - 6 entries 3 Connected, 0 Static, 3 RIP, 0 BGP, 0 OSPF Number of prefixes: /112: 6 C 1111::/112 [1/1] via ::, vlan10 R 2222::/112 [3/120] via fe80::221:28ff:fe56:d7a9, vlan40 R 3333::/112 [2/120] via fe80::221:28ff:fe56:d7a9, vlan40 C 4444::/112 [1/1] via ::, vlan40 R 5555::/112 [2/120] via fe80::221:28ff:fe56:d7a9, vlan40 C 6666::/112 [1/1] via ::, vlan10
SEFOS 3 SEFOS# show ipv6 rip RIP port 521, multicast-group ff02::9,Maximum paths is 16 Updates every 30 seconds; expire after 180SEFOS 3 SEFOS# show ipv6 rip database Garbage Collect after 120 secondsRIP local RIB 1111::/112, metric 3, ripng vlan30/fe80::221:28ff:fe56:d7a9, expires in 180 secs 2222::/112, metric 1, local vlan20/::, expires in 180 secs 3333::/112, metric 2, ripng vlan30/fe80::221:28ff:fe56:d7a9, expires in 180 secs 3333::/112, metric 1, local vlan30/::, expires in 180 secs 4444::/112, metric 2, ripng vlan30/fe80::221:28ff:fe56:d7a9, expires in 180 secs 5555::/112, metric 2, ripng vlan30/fe80::221:28ff:fe56:d7a9, expires in 180 secs 6666::/112, metric 3, ripng vlan30/fe80::221:28ff:fe56:d7a9, expires in 180 secs Poison Reverse is on Interface: vlan20 vlan30 Redistribution: Connected,Routes Redistribution is enabled.
SEFOS 3 SEFOS# show ipv6 route IPv6 Routing Table - 7 entries Codes : C - Connected, S - StaticSEFOS 3 SEFOS# show ipv6 route summary O - OSPF, R - RIP, B - BGPIPv6 Routing Table Summary - 7 entries 2 Connected, 0 Static, 5 RIP, 0 BGP, 0 OSPF Number of prefixes: /112: 7 R 1111::/112 [3/120] via fe80::221:28ff:fe56:d7a9, vlan30 C 2222::/112 [1/1] via ::, vlan20 C 3333::/112 [1/1] via ::, vlan30 R 3333::/112 [2/120] via fe80::221:28ff:fe56:d7a9, vlan30 R 4444::/112 [2/120] via fe80::221:28ff:fe56:d7a9, vlan30 R 5555::/112 [2/120] via fe80::221:28ff:fe56:d7a9, vlan30 R 6666::/112 [3/120] via fe80::221:28ff:fe56:d7a9, vlan30
