| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System RIPng Administration Guide |
Configuring the RIPng Topology Example
Enable and Configure RIPng on Desired IPv6 Interfaces
Disable the split-horizon Option
The following example disables the redistribution of directly connected routes (5555::0) on SEFOS1. With redistribution disabled, the route to 5555::0 is not visible on switches SEFOS2 and SEFOS3.
SEFOS 2 SEFOS# show ipv6 route
IPv6 Routing Table - 6 entries
Codes : C - Connected, S - Static
O - OSPF, R - RIP, B - BGP
C 1111::/112 [1/1]
via ::, vlan10
R 2222::/112 [3/120]
via fe80::221:28ff:fe56:d7a9, vlan40
R 3333::/112 [2/120]
C 4444::/112 [1/1]
via ::, vlan40
R 5555::/112 [2/120]
C 6666::/112 [1/1]
via ::, vlan10SEFOS 3 SEFOS# show ipv6 route
IPv6 Routing Table - 7 entries
R 1111::/112 [3/120]
via fe80::221:28ff:fe56:d7a9, vlan30
C 2222::/112 [1/1]
via ::, vlan20
C 3333::/112 [1/1]
via ::, vlan30
R 4444::/112 [2/120]
R 6666::/112 [3/120]
via fe80::221:28ff:fe56:d7a9, vlan30SEFOS 1 SEFOS# configure terminal SEFOS 1 SEFOS(config)# ipv6 route rip SEFOS 1 SEFOS(config-router)# no redistribute connected SEFOS 1 SEFOS(config-router)# exit
Note that 5555::/112 [2/120] is missing from the output.
IPv6 Routing Table - 5 entries
C 1111::/112 [1/1]
via ::, vlan10
R 3333::/112 [3/120]
C 4444::/112 [1/1]
via ::, vlan40
C 6666::/112 [1/1]
via ::, vlan10Note that 5555::/112 [2/120] is missing from the output.
C 2222::/112 [1/1]
via ::, vlan20
C 3333::/112 [1/1]
via ::, vlan30
R 4444::/112 [3/120]
