| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System RIPng Administration Guide |
Configuring the RIPng Topology Example
Enable and Configure RIPng on Desired IPv6 Interfaces
Disable the split-horizon Option
Use the following commands to configure VLAN 20 and VLAN 30 on SEFOS3 in the example topology.
SEFOS 3 SEFOS# configure terminal SEFOS 3 SEFOS(config)# set gvrp disable SEFOS 3 SEFOS(config)# set gmrp disable SEFOS 3 SEFOS(config)# interface extreme-ethernet 0/65 SEFOS 3 SEFOS(config-if)# no shutdown SEFOS 3 SEFOS(config-if)# switchport access vlan 20 % Access VLAN does not exist.,Creating vlan SEFOS 3 SEFOS(config-if)# exit SEFOS 3 SEFOS(config)# interface vlan 20 SEFOS 3 SEFOS(config-if)# no shutdown SEFOS 3 SEFOS(config-if)# ipv6 enable SEFOS 3 SEFOS(config-if)# ipv6 address 2222::13 112 SEFOS 3 SEFOS(config-if)# exit SEFOS 3 SEFOS(config)# vlan 30 SEFOS 3 SEFOS(config-vlan)# port extreme-ethernet 0/1 SEFOS 3 SEFOS(config-vlan)# exit SEFOS 3 SEFOS(config)# interface extreme-ethernet 0/1 SEFOS 3 SEFOS(config-if)# no shutdown SEFOS 3 SEFOS(config-if)# exit SEFOS 3 SEFOS(config)# interface vlan 30 SEFOS 3 SEFOS(config-if)# no shutdown SEFOS 3 SEFOS(config-if)# ipv6 enable SEFOS 3 SEFOS(config-if)# ipv6 address 3333::13 112 SEFOS 3 SEFOS(config-if)# end
SEFOS 3 SEFOS# show ipv6 interface
vlan1 is up, line protocol is up
IPv6 is Enabled
Link local address:
fe80::214:4fff:fe6c:686d
Global unicast address(es):
Not Configured.
Joined group address(es):
ff02::1
ff02::2
ff02::1:ff6c:686d
MTU is 9216
ICMP redirects are enabled
ND DAD is enabled, Number of DAD attempts: 1
ND router advertisement is disabled
vlan20 is up, line protocol is up
IPv6 is Enabled
Link local address:
2222::13/112
ff02::1
ff02::2
ff02::9
ff02::1:ff00:13
ff02::1:ff6c:686d
MTU is 9216
vlan30 is up, line protocol is up
IPv6 is Enabled
Link local address:
3333::13/112
ff02::1
ff02::2
ff02::9
ff02::1:ff00:13
ff02::1:ff6c:686d
MTU is 9216
SEFOS 3 SEFOS#
