| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System RIPng Administration Guide |
Enable and Configure RIPng on Desired IPv6 Interfaces
Disable the split-horizon Option
This section describes a simple RIPng topology example and configuration. These configurations are examples and used for illustration purposes only. Variables such as interfaces, IP addresses, and others would be different based on your site topology and configuration.
