| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS REM HBA Installation Guide For HBA Models SGX-SAS6-REM-Z and SG-SAS6-REM-Z |
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Chapter 4 HBA Software Installation
MegaRAID Storage Manager-Related Issues
Cannot Upgrade Firmware on the HBA Through MSM
Cannot Assign a Global Hot Spare Through the MSM GUI
Non-Alphabetical Characters Are Displayed in RAID Volume Names
Cannot Delete a RAID Volume Using the SAS2IRCU Utility
There Is No FCode Utility Command for Creating a RAID 10 Volume
Virtual Drives Are Displayed Twice
A Hard Drive is Not Displayed in the BIOS Setup Utility
Cannot View Newly Inserted Drive
Blue Ready-to-Remove LED Does Not Illuminate After Issuing the cfgadm -c unconfigure Command
Determine the Physical Location, and Then Hot Plug, a Disk
Only 24 Devices Are Displayed In The System BIOS Boot List
Typing Ctrl+N Does Not Initiate a Network Boot Nor Load the HBA Option ROM As Expected
The Oracle Solaris Operating System Installation Hangs
The System Hangs After Deleting a RAID Volume
This sections contains the following information:
