| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS REM HBA Installation Guide For HBA Models SGX-SAS6-REM-Z and SG-SAS6-REM-Z |
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Chapter 4 HBA Software Installation
MegaRAID Storage Manager-Related Issues
Cannot Upgrade Firmware on the HBA Through MSM
Cannot Assign a Global Hot Spare Through the MSM GUI
Non-Alphabetical Characters Are Displayed in RAID Volume Names
Cannot Delete a RAID Volume Using the SAS2IRCU Utility
There Is No FCode Utility Command for Creating a RAID 10 Volume
Virtual Drives Are Displayed Twice
A Hard Drive is Not Displayed in the BIOS Setup Utility
Cannot View Newly Inserted Drive
Blue Ready-to-Remove LED Does Not Illuminate After Issuing the cfgadm -c unconfigure Command
Determine the Physical Location, and Then Hot Plug, a Disk
Only 24 Devices Are Displayed In The System BIOS Boot List
The Oracle Solaris Operating System Installation Hangs
The System Hangs After Deleting a RAID Volume
Bug 15601623
Issue: If the HBA is installed in an x86 system, and you type Ctrl+N on the serial console to initiate a network boot, the network boot might not be initiated, and the Option ROM for the HBA might not be loaded.
Workaround: Do one of the following:
Use the ILOM Remote Console and press F12 to initiate a network boot.
If using the serial console, type Ctrl+E to get to the BIOS Boot Device Priority menu, and then move the desired PXE adapter (network boot device) to the top of the Boot Device Priority list. The PXE adapter will then be used as the boot device.
Type Ctrl+N during, or after, the HBA Option ROM code is running. The Option ROM code is running when the following banner is displayed: LSI Corporation MPT SAS2 BIOS. Copyright 2000-2010 LSI Corporation.
