| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS ExpressModule HBA Installation Guide For HBA Models SGX-SAS6-EM-Z and SG-SAS6-EM-Z |
Chapter 2 Hardware Installation and Removal
Observing ESD and Handling Precautions
Chapter 3 Creating a Bootable Drive in a Preboot Environment
See the Safety and Compliance documentation for this HBA.
See HBA Features.
The HBA has two external x4 mini-SAS connectors, each connecting to four 6 Gb SAS ports. You will need to use the appropriate cable to connect the HBA to SAS versus SATA storage devices.
For connection to external drives or backplanes, you must use an external cable with a standard mini-SAS connector (SFF-8088) on the controller side of the cable.
Use only Oracle-provided SAS cables. For more information or to purchase cables for your Oracle system, go to http://www.oracle.com. Cable connectors are keyed so that you cannot insert them incorrectly.
