Skip Navigation Links
Exit Print View
Sun Storage 6 Gb SAS ExpressModule HBA
Installation Guide For HBA Models SGX-SAS6-EM-Z and SG-SAS6-EM-Z
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 HBA Overview
Chapter 2 Hardware Installation and Removal
Observing ESD and Handling Precautions
Installing the HBA
To Prepare for Hardware Installation
To Install the HBA
HBA LEDs
Port to Phys Mapping
To Complete the Installation
Next Steps
Removing the HBA
To Remove the HBA
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Chapter 4 HBA Software Installation
Chapter 5 Known Issues
Appendix A HBA Specifications
Glossary
To Remove the HBA
  1. Prepare your operating system for HBA removal.
  2. Attach an ESD wrist strap.
    See Observing ESD and Handling Precautions.
  3. Disconnect all SAS cables from the external mini-SAS connectors.
  4. Press the Attention button on the exposed end of the HBA (see External Connectors and LEDs.).
  5. When the green Power LED next to the Attention button goes out, pull the ejection lever downward.
    Note - If you decide after pressing the Attention button that you do not want to remove the HBA, you can cancel the operation by pressing the button again within 5 seconds of when the power LED starts blinking.
  6. Pull the HBA out of its slot in the enclosure.
