To Install the HBA
- Attach
an ESD wrist strap and remove the HBA from its protective bag.
See Observing ESD and Handling Precautions.
- Refer to your system installation
or service manual to determine how to locate an empty PCIe ExpressModule
slot in which you can insert the HBA.
- Grasp the button (the latching
mechanism at the end of the ejection lever) on the front of the
HBA and pivot the lever downward.
- Insert the HBA into an available
PCIe ExpressModule slot in the chassis, as shown in Installing the HBA into a PCIe Slot.
Figure 2-1 Installing the HBA into a
PCIe Slot
Figure Legend
1
Chassis
2Ejection Lever (Open)
Note - The configuration of the enclosure in your system might
not be the same as shown in this illustration.
- When the HBA is fully inserted
in the slot, pivot the ejection lever up to the locked position.
- Connect SAS cables to the two
external x4 mini-SAS connectors and attach the other end of the
cables to the disk drives or other SAS/SATA devices, per your requirements.
Use only Oracle-provided SAS cables (530-3887-01), available
for purchase at: http://www.oracle.com
- Observe the LEDs to ensure normal
operation of the HBA.
For more information about the LEDs, see HBA LEDs.
