| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS ExpressModule HBA Installation Guide For HBA Models SGX-SAS6-EM-Z and SG-SAS6-EM-Z |
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Overview of Creating a Bootable Drive in a Preboot Environment
Creating a Bootable Drive (SPARC)
To Create a Bootable Drive (SPARC)
Using the OBP Environment to Set Up a Bootable Drive (SPARC)
To Prepare to Create a Bootable Drive (SPARC)
Creating an Alias for a Bootable Drive (SPARC)
To Create an Alias for a Bootable Drive (SPARC)
Creating a Bootable Drive (x86)
To Create a Bootable Drive (x86)
Using the BIOS Configuration Utility to Set Up a Bootable Drive (x86)
To Prepare to Use the BIOS Configuration Utility
Selecting a Bootable Drive (x86)
To Select a Bootable Drive (x86)
Validating the Oracle Solaris Labels of the HBA Drives
To Verify That the Oracle Solaris Label of a Drive is Valid
Installing the Oracle Solaris OS
To Prepare to Install the Oracle Solaris OS
http://www.oracle.com/technetwork/server-storage/solaris10/overview/index.html
You can obtain these Oracle Solaris patches at:
# reboot
The system will now be able to see, and boot from, the logical drive on which you installed the Oracle Solaris OS.
