| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS ExpressModule HBA Installation Guide For HBA Models SGX-SAS6-EM-Z and SG-SAS6-EM-Z |
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Creating a Bootable Drive (SPARC)
To Create a Bootable Drive (SPARC)
Using the OBP Environment to Set Up a Bootable Drive (SPARC)
To Prepare to Create a Bootable Drive (SPARC)
Creating an Alias for a Bootable Drive (SPARC)
To Create an Alias for a Bootable Drive (SPARC)
Creating a Bootable Drive (x86)
To Create a Bootable Drive (x86)
Using the BIOS Configuration Utility to Set Up a Bootable Drive (x86)
To Prepare to Use the BIOS Configuration Utility
Selecting a Bootable Drive (x86)
To Select a Bootable Drive (x86)
Validating the Oracle Solaris Labels of the HBA Drives
To Verify That the Oracle Solaris Label of a Drive is Valid
Installing the Oracle Solaris OS
To Prepare to Install the Oracle Solaris OS
To Install the Oracle Solaris OS
You can choose to install the HBA into a system that does not yet have an OS installed. You can then install the OS onto a physical drive to enable you to boot from the HBA. On a SPARC system, you would perform these actions through the OpenBoot Prom (OBP) environment. On an x86 system, you would do so through the BIOS Configuration utility.
Based on the type of system in which you are installing the HBA, follow the procedures in one of the following sections:
If you are installing the HBA into a SPARC system, go to Creating a Bootable Drive (SPARC).
If you are installing the HBA into an x86 system, go to Creating a Bootable Drive (x86).
