| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS ExpressModule HBA Installation Guide For HBA Models SGX-SAS6-EM-Z and SG-SAS6-EM-Z |
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Overview of Creating a Bootable Drive in a Preboot Environment
Creating a Bootable Drive (SPARC)
To Create a Bootable Drive (SPARC)
Using the OBP Environment to Set Up a Bootable Drive (SPARC)
To Prepare to Create a Bootable Drive (SPARC)
Creating a Bootable Drive (x86)
To Create a Bootable Drive (x86)
Using the BIOS Configuration Utility to Set Up a Bootable Drive (x86)
To Prepare to Use the BIOS Configuration Utility
Selecting a Bootable Drive (x86)
To Select a Bootable Drive (x86)
Validating the Oracle Solaris Labels of the HBA Drives
To Verify That the Oracle Solaris Label of a Drive is Valid
Installing the Oracle Solaris OS
To Prepare to Install the Oracle Solaris OS
To Install the Oracle Solaris OS
This section describes how to create an alias for the drive that you selected in To Prepare to Create a Bootable Drive (SPARC). This section contains the following topic:
Creating an alias for the drive helps simplify the process of booting the drive later. In the following example, the alias name is mydev.
{0} ok nvalias mydev /pci@1e,600000/pci@0/pci@3/LSI,sas@0/disk
{0} ok boot mydev
{0} ok printenv boot-device
boot-device = disk0 disk1
{0} ok setenv boot-device mydev disk0
boot-device = mydev disk0
In this example, the mydev alias is set as disk0, the first disk in the boot device list. This results in the automatic booting of the bootable drive, /pci@1e,600000/pci@0/pci@3/LSI,sas@0/disk.
Validate the label of the bootable drive that you created (See Validating the Oracle Solaris Labels of the HBA Drives).
