| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS ExpressModule HBA Installation Guide For HBA Models SGX-SAS6-EM-Z and SG-SAS6-EM-Z |
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Overview of Creating a Bootable Drive in a Preboot Environment
Creating a Bootable Drive (SPARC)
To Create a Bootable Drive (SPARC)
Creating an Alias for a Bootable Drive (SPARC)
To Create an Alias for a Bootable Drive (SPARC)
Creating a Bootable Drive (x86)
To Create a Bootable Drive (x86)
Using the BIOS Configuration Utility to Set Up a Bootable Drive (x86)
To Prepare to Use the BIOS Configuration Utility
Selecting a Bootable Drive (x86)
To Select a Bootable Drive (x86)
Validating the Oracle Solaris Labels of the HBA Drives
To Verify That the Oracle Solaris Label of a Drive is Valid
Installing the Oracle Solaris OS
To Prepare to Install the Oracle Solaris OS
To Install the Oracle Solaris OS
This section describes how to use the OBP environment to select a drive that you can use as your boot drive upon which to install the Oracle Solaris OS. This section contains the following topic:
The mpt_sas-based controllers will end with LSI,sas@number.
{0} ok show-devs
/pci@1e,600000/pci@0/pci@3/LSI,sas@0
/pci@1e,600000/pci@0/pci@3/LSI,sas@0/disk
/pci@1e,600000/pci@0/pci@3/LSI,sas@1
{0} ok select /pci@1e,600000/pci@0/pci@3/LSI,sas@0
{0} ok .properties
subsystem-id 000031c0
The ExpressModule facing cards contain a subsystem-ID of 000031c0. To further specify the card, you can also display the SAS addresses of any connected drives by using the show-children command.
