| Skip Navigation Links | |
| Exit Print View | |
Oracle Fusion Middleware Administration Guide for Oracle Unified Directory 11g Release 1 (11.1.1) |
1. Starting and Stopping the Server
2. Configuring the Server Instance
3. Configuring the Proxy Components
4. Configuring Security Between Clients and Servers
5. Configuring Security Between the Proxy and the Data Source
6. Managing Oracle Unified Directory With Oracle Directory Services Manager
10. Managing Users and Groups With dsconfig
11. Managing Password Policies
13. Monitoring Oracle Unified Directory
Configuring Logs With the Log Publisher
To List Existing Log Publishers
Configuring Log Retention Policies
To View the Log Retention Policies
To Create a Log Retention Policy
To Modify a Log Retention Policy
Configuring Log Rotation Policies
To View the Log Rotation Policies
To Create a Log Rotation Policy
To Set Log Rotation or Retention for a Specific Log File
Configuring Alerts and Account Status Notification Handlers
To View All Configured Alert Handlers
Managing Account Status Notification Handlers
To View the Configured Account Status Notification Handlers
To Enable Account Status Notification Handlers
To Create a New Account Status Notification Handler
To Delete an Account Status Notification Handler
Monitoring the Server With LDAP
Viewing Monitoring Information Using the cn=monitor Entry
Monitored Attributes in the Oracle Unified Directory proxy
To View the Available Monitoring Information
To Monitor General-Purpose Server Information
To Monitor Version Information
To Monitor the User Root Back End
To Monitor the Backup Back End
To Monitor the monitor Back End
To Monitor the Schema Back End
To Monitor the adminRoot Back End
To Monitor the ads-truststore Back End
To Monitor the LDAP Connection Handler
To Monitor LDAP Connection Handler Statistics
To Monitor Connections on the LDAP Connection Handler
To Monitor the Administration Connector
To Monitor Administration Connector Statistics
To Monitor Connections on the Administration Connector
To Monitor the LDIF Connection Handler
To Monitor JVM Stack Trace Information
To Monitor the JVM Memory Usage
To Monitor the userRoot Database Environment
To Monitor Remote LDAP Servers
To Monitor a Global Index Catalog
Monitoring Using the manage-tasks Command
Monitoring the Server With JConsole
To Configure JMX on a Server Instance
Accessing a Server Instance From JConsole
Viewing Monitoring Information With JConsole
To View the Replication Repair Logs
Monitoring the Server With SNMP
Configuring the SNMP Connection Handler and Its Dependencies
To Configure SNMP in the Server
To View the SNMP Connection Handler Properties
To Access SNMP on a Server Instance
SNMP Security Configuration: V1 and V2c
SNMP Security Configuration: V3
Monitoring a Replicated Topology
Monitoring Replication Status With dsreplication
Advanced Replication Monitoring
To Monitor the Topology and Its Connections
To Monitor Replication Latency
To Monitor Replication Security
To Monitor Replication Conflicts
Monitor providers are enabled by default and provide information about the server that can be useful for monitoring or troubleshooting purposes. The cn=monitor entry contains the monitoring information that is published by the monitor providers. When the monitor provider is disabled, the provided information is no longer available under cn=monitor.
Monitor providers can be configured by using the dsconfig command. For more information, see Managing the Server Configuration With dsconfig.
$ dsconfig -h localhost -p 4444 -D "cn=directory manager" -w password -n \ list-monitor-providers
Monitor Provider : Type : enabled -------------------:-------------------:-------- Client Connections : client-connection : true Entry Caches : entry-cache : true JVM Memory Usage : memory-usage : true JVM Stack Trace : stack-trace : true System Info : system-info : true Version : version : true
For example, to set the JVM Stack Trace monitor provider to false, use the following command:
$ dsconfig -h localhost -p 4444 -D "cn=Directory Manager" -w password -X -n \ set-monitor-provider-prop --provider-name "JVM Stack Trace" --set enabled:false
Running the dsconfig command with the list-monitor-providers subcommand now shows the JVM Stack Trace monitor provider as false:
Monitor Provider : Type : enabled -------------------:-------------------:-------- Client Connections : client-connection : true Entry Caches : entry-cache : true JVM Memory Usage : memory-usage : true JVM Stack Trace : stack-trace : false System Info : system-info : true Version : version : true
