| Skip Navigation Links | |
| Exit Print View | |
man pages section 4: File Formats Oracle Solaris 10 8/11 Information Library |
- ASET master files
/usr/aset/masters/tune.low
/usr/aset/masters/tune.med
/usr/aset/masters/tune.high
/usr/aset/masters/uid_aliases
/usr/aset/masters/cklist.low
/usr/aset/masters/cklist.med
/usr/aset/masters/cklist.high
The /usr/aset/masters directory contains several files used by the Automated Security Enhancement Tool (ASET). /usr/aset is the default operating directory for ASET. An alternative working directory can be specified by the administrators through the aset -d command or the ASETDIR environment variable. See aset(1M).
These files are provided by default to meet the need of most environments. The administrators, however, can edit these files to meet their specific needs. The format and usage of these files are described below.
All the master files allow comments and blank lines to improve readability. Comment lines must start with a leading "#" character.
These files are used by the tune task (see aset(1M)) to restrict the permission settings for system objects. Each file is used by ASET at the security level indicated by the suffix. Each entry in the files is of the form:
pathname mode owner group type
where
is the full pathname
is the permission setting
is the owner of the object
is the group of the object
is the type of the object It can be symlink for a symbolic link, directory for a directory, or file for everything else.
Regular shell wildcard ("*", "?", ...) characters can be used in the pathname for multiple references. See sh(1). The mode is a five-digit number that represents the permission setting. Note that this setting represents a least restrictive value. If the current setting is already more restrictive than the specified value, ASET does not loosen the permission settings.
For example, if mode is 00777, the permission will not be changed, since it is always less restrictive than the current setting.
Names must be used for owner and group instead of numeric ID's. ? can be used as a “don't care” character in place of owner, group, and type to prevent ASET from changing the existing values of these parameters.
This file allows user ID's to be shared by multiple user accounts. Normally, ASET discourages such sharing for accountability reason and reports user ID's that are shared. The administrators can, however, define permissible sharing by adding entries to the file. Each entry is of the form:
uid=alias1=alias2=alias3= ...
where
is the shared user id
is the user accounts sharing the user ID
For example, if sync and daemon share the user ID 1, the corresponding entry is:
1=sync=daemon
These files are used by the cklist task (see aset(1M)), and are created the first time the task is run at the low, medium, and high levels. When the cklist task is run, it compares the specified directory's contents with the appropriate cklist.level file and reports any discrepancies.
Example 1 Examples of Valid Entries for the tune.low, tune.med, and tune.high Files
The following is an example of valid entries for the tune.low, tune.med, and tune.high files:
/bin 00777 root staffsymlink /etc 02755 root staffdirectory /dev/sd* 00640 rootoperatorfile
ASET Administrator Manual
