Installing Software for the
VMware Technology
Before using the universal HBA, check the Oracle support area
of the QLogic web site for the latest drivers. The drivers and utilities,
as well as their associated Readme files,
are located at: http://driverdownloads.qlogic.com/QLogicDriverDownloads_UI/Oracle_Search.aspx
To Install the Universal HBA
Software for the VMware Technology
- Go
to the Oracle support area of the QLogic web site at: http://driverdownloads.qlogic.com/QLogicDriverDownloads_UI/Oracle_Search.aspx
- Perform a search for the universal
HBA by using the HBA part number (7101682).
- Scroll to the VMware Driver section
and locate the driver version that you want to download.
If the universal HBA is running in CNA/FCoE mode, you might
need to update both the FC/FCoE driver and the network driver that
are available in this section.
- Click the driver version that
you want to download, and then click Download Now.
- Save the file to a directory
on the hard disk of the system.
- Follow the installation instructions
in the Readme file associated
with the driver to complete the driver installation.
- Repeat steps 1 through 6 for any additional VMware drivers and utilities that your system
requires.
