This chapter contains these topics:
Section 3.3, "Configuring the WebLogic Domain for Oracle Access Manager"
Section 3.5, "Configuring Oracle HTTP Server for WebCenter Spaces"
Section 3.6, "Registering the WebGate Agent for WebCenter Spaces"
The WebCenter server ensures the SSO credentials are valid without the user logging in again.
Install WebCenter Database Schemas (See Appendix A)
Install WebLogic Server (See Appendix B)
Important: The WebCenter database schemas must be created, and the WebLogic Server must be installed before you install Oracle WebCenter Spaces.
You install Oracle WebCenter Spaces 11.1.1.5.0.
When you install the WebCenter components on your machine, be sure to enter the correct data (machine name, ports, and so on) for your configuration. When you download the software from Oracle Technology Network (OTN) note the directories to which you downloaded the software and replace the directory location specified in this chapter with your directory locations. Be sure to install the executable files for your platform.
Use these steps to install Oracle WebCenter spaces 11.1.1.5.0.
Download and unzip the WebCenter installation file:
ofm_wc_generic_11.1.1.5.0_disk1_1of1.zip
Execute the install process from Disk1 folder:
On Windows: setup.exe with Run as administrator option
On UNIX: ./runInstaller as a non-root user
Review the Welcome page information, and then click Next.
Select your Software Updates option.
The installer performs prerequisite checks.
Enter a Middleware Home and a WebCenter Home Directory.
Select the application server.
EnterpriseOne supports only a WebLogic Server as the application server.
Click Next.
Review the Install Summary.
Click Install to start the install process.
Click Next to continue.
Click Finish when the install process is completed.
Run config.cmd (.sh) from <MW_Home>\Oracle_WC1\common\bin folder to create the WebCenter domain.
Select Create a new WebLogic domain option.
Select the products to be part of this domain. You can add more products later.
Click Next.
Enter the domain name.
Enter the domain Administrator user and password.
Select Production Mode.
Verify the available JDK.
Enter the JDBC Component Schema database connection.
Test JDBC Schema connection.
Select the Administration Server and Managed Server, Cluster and Machine.
See Appendix B to complete the domain creation.
Start the WebCenter Admin Server (startWebLogic.cmd (.sh)) from <MW_Home>\user_projects\domains\<webcenter_domain>\bin folder.
Start WebLogic NodeManager (startNodeManager.cmd/sh) from <MW_home>\wlserver_10.3\server\bin.
The startNodeManager process creates a nodemanager.properties file in <MW_home>\wlserver_10.3\common\nodemanager folder.
Once the file is created, run setNMProps.cmd/.sh from <MW_home>oracle_common\common\bin folder.
Another option is that you can edit the nodemanager.properties by opening the file with an editor and change StartScriptEnabled to true.Important:
WebCenter Spaces will not start correctly if this value is not set.After the value is changed, you must stop and restart NodeManager.
Start the domain Admin Server and WC_Spaces.
After the Admin Server is started, you can access the domain console, Enterprise Manager, and WebCenter Spaces.
http://server:7001/console (Enterprise Manager)
http://server:7001/em (Domain Console)
http://server:8888/webcenter
Click About WebCenter Spaces on the bottom right to verify the version level.
Configuring the WebLogic Domain for OAM consists of these tasks:
Configuring the Oracle Internet Directory Authenticator
Configuring the OAM Identity Asserter
Assuming Oracle Internet Directory is backing the Oracle Access Manager (OAM) identity store, an Oracle Internet Directory authenticator (OracleInternetDirectoryAuthenticator) should be configured for the LDAP server that is used as the identity store of OAM, and the provider should be set to SUFFICIENT.
Use these steps to configure the Oracle Internet Directory Authenticator.
Log in to the WebCenter WebLogic Server Administration Console.
From the Domain Structure pane, click Security Realms
Select the realm entry for which to configure the OID authenticator.
Select the Providers tab.
Click New to create a provider.
Enter a name for the new provider (for example, OID Authenticator), select OracleInternetDirectoryAuthenticator as the type, and then click OK.
On the Providers tab, click the newly added provider. The common setting pane appears.
Set the control flag to SUFFICIENT and click Save.
Open the Provider Specific tab.
Complete the fields as shown in the table below. Leave the rest of the fields set to their default values.
| Field | Value | Comment |
| Host: | The host ID for the LDAP server | |
| Port: | The LDAP server port number | |
| Principal: | The LDAP administrator principal | |
| Credential: | <password> | The administrator principal password |
| Confirm Credential: | <password> | |
| User Base DN: | User Search Base - this value should be the same as for the OAM Access Manager setup. | |
| All User Filter: | (&(uid=*)(objectclass=person)) | |
| User Name Attribute | uid | |
| Group Base DN: | Group search base - same as user base DN | |
| Use Retrieved User Name as Principal | Checked | User login IDs are usually case insensitive. This flag is required so that the subject established contains the user name as stored in the OID. |
Click Save.
In a WebLogic Server domain where JRF is installed, the JRF template is present as part of the domain in an Oracle Fusion Middleware product. In this case, the OAM Identity Asserter and OAM Authentication Provider are automatically available for configuration. If JRF is not installed in your WebLogic domain, you must add the OAMAuthnProvider.jar to a specific location in your domain.
Configuring the OAM Identity Asserter consists of these tasks:
Adding the OAM Identity Asserter
Configuring the Default Authenticator and Provider Order
Adding an OAM Single sign-On Provider
Confirm the required JAR and WAR files as follows:
Confirm the location of required JAR files in the following Fusion Middleware path:
<MW_Home>/oracle_common/modules/oracle.oamprovider_11.1.1/oamAuthnProvider.jar
Locate the console-extension WAR file in the following path:
<MW_Home>/oracle_common/modules/oracle.oamprovider_11.1.1/oamauthenticationprovider.war
Copy the WAR file to the following path in the WebLogic Server home:
<MW_Home>/wlserver_10.3/server/lib/console-ext/autodeploy/oamauthenticationprovider.war
An OAM identity asserter must be configured with the provider control flag set to required.
Use these steps to add the OAM Identity Asserter.
From the Domain Structure pane, click Security Realms.
Click the realm entry for which to configure the OAM identity asserter.
From the Providers tab, click New.
Enter a name for the new provider (for example, OAM ID Asserter), select OAMIdentityAsserter as its type and click OK.
Set the control flag to REQUIRED and check that OAM_REMOTE_USER and ObSSOCookie are set for Active Types.
Click Save to save your settings.
After configuring the OAM identity asserter, ensure that the default authenticator's control flag is set to SUFFICIENT and reorder the providers.
Use these steps to configure the default authenticator and provider order.
Navigate to the Provider Settings pane.
Open the Default Authenticator and set the control flag to SUFFICIENT.
Do the same for any providers other than the two you just created.
On the Setting Pane, reset the provider order to:
OAMIdentityAsserter(REQUIRED)
OracleInternetDirectoryAuthenticator (SUFFICIENT)
DefaultAuthenticator (SUFFICIENT)
DefaultIdentityAsserter
On Windows platform, if your WebLogic user is not part of the OID Administrators group, you will not be able to restart the WebLogic Admin Server.You can use these steps to add an Administrators group and add your user in it.
Connect to Oracle Directory Manager
Create a new Group, Administrators. You can use the Create Like option.
Add your admin user to this group
Now, you should able to start the WebLogic Admin Server.
After checking that the default authenticator's control flag is set correctly and that the order of the providers is correct, add an OAM SSO provider and restart all servers.
Connect to the WebLogic domain using WLST and run the following command:
Start WLST.cmd or WLST.sh from <MW_Home>oracle_common\common\bin folder
Connect ('admin-user','admin-password','t3://localhost:7001')
addOAMSSOProvider (loginuri="/${app.context}/adfAuthentication",logouturi="/oamsso/logout.html")
Exit the tool.
Restart all servers.
Next, you install Oracle WebGate 11.1.1.5.
Oracle HTTP Server WebGate is a web server plug-in that is shipped out-of-the-box with Oracle Access Manager. The Oracle HTTP Server WebGate intercepts HTTP requests from users for web resources and forwards them to the Access Server for authentication and authorization. Oracle HTTP Server WebGate installation packages are found on media and virtual media that is separate from the core components.
Install Oracle HTTP Server (See Appendix C)
If you are installing Oracle HTTP Server 11g WebGate for Oracle Access Manager on a Linux or Solaris operating system, you must download and install third-party GCC libraries on your machine.
You can download the appropriate GCC library from the following third-party website:
| Operating System | Architecture | GCC Libraries | Required Library Version |
| Linux 64-bit | x64 | libgcc_s.so.1
libstdc++.so.6 |
3.4.6 |
| Solaris 64-bit | SPARC | libgcc_s.so.1
libstdc++.so.5 |
3.3.2 |
If you are using Windows 2008 64-bit operating systems, you must install Microsoft Visual C++ 2005 libraries on the machine hosting the Oracle HTTP Server 11g WebGate.
The libraries are included in the Microsoft Visual C++ 2005 SP1 Redistributable Package (x64), which can be downloaded from the following website:
Use these steps to install Oracle HTTP 11g WebGate.
Download and unzip ofm_oam_webgates_generic_11.1.1.5.0_disk1_1of1.zip.
Launch the installer:
On Windows: setup.exe with Run as administratoroption.
On UNIX: ./RunInstaller as a non-root user.
Specify JRE/JDK location.
Click Next on the Welcome page.
Oracle HTTP WebGate supports Oracle HTTP version 11.1.1.2 or 11.1.1.3. EnterpriseOne configuration supports version 11.1.1.5. See Appendix A to upgrade to Version 11.1.1.5.
This image shows the prerequisite checks on Linux operating system:
Specify the Middleware Home and WebGate Home Directory.
Review the installation Summary.
Click Install.
Click Next when the installation is completed.
Click Finish when the installation is completed.
You must complete the following steps after installing Oracle HTTP Server 11g WebGate for Oracle Access Manager:
Move to the following directory under your Oracle Home for WebGate:
On UNIX operating systems:
<webgate_home>/webgate/ohs/tools/deployWebGate
On Windows operating systems:
<webgate_home>\webgate\ohs\tools\deployWebGate
On the command line, run the following command to copy the required bits of agent from the Webgate_Home directory to the WebGate instance location:
./deployWebgateInstance.sh -w <Webgate_Instance_Directory> -oh <Webgate_Oracle_Home>
deploy WebgateInstance.bat -w <Webgate_Instance_Directory> -oh <Webgate_Oracle_Home>
Where <Webgate_Oracle_Home> is the directory where you have installed Oracle HTTP Server WebGate and created as the Oracle Home for WebGate.
For example: <MW_Home>/Oracle_OAMWebGate1
The <Webgate_Instance_Directory> is the location of WebGate Instance Home, which is same as the Instance Home of Oracle HTTP Server.
For example: <MW_Home>/Oracle_WT1/instances/instance1/config/OHS/ohs1
Run the following command to ensure that the LD_LIBRARY_PATH variable contains <Oracle_Home_for_Oracle_HTTP_Server>/lib:
Export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:<Oracle_Home_for_Oracle_HTTP_Server>/lib
Set the <Webgate_Installation_Directory>\webgate\ohs\lib location in the PATH environment variable.
From your present working directory, move up one directory level:
<webgate_home>/webgate/ohs/tools/setup/InstallTools
<webgate_home>\webgate\ohs/tools\editHttpConf
On the command line, run the following command to copy the apache_webgate.template from the Webgate_Home directory to the Webgate Instance location (renamed to webgate.conf) and update the httpd.conf file to add one line to include the name of webgate.conf:
./EditHttpConf -w <Webgate_Instance_Directory> [-oh <Webgate_Oracle_Home>] [-o <output_file>]
EditHttpConf.exe -w <Webgate_Instance_Directory> [-oh <Webgate_Oracle_Home>] [-o <output_file>]
The [-oh <Webgate_Oracle_Home>] and [-o <output_file>] parameters are optional.Verify the updated httpd.conf.
The following line is added to the bottom of the file:
Do not restart the Oracle HTTP server until the WebGate agent is registered for WebCenter Spaces; errors will continue to display in the command line if the Oracle HTTP server processes are restarted.After you install and configure Oracle HTTP Server and Oracle HTTP WebGate, you configure the Oracle HTTP server for WebCenter Spaces.
Use the following example to configure mod_wl_ohs.conf. Verify that WebLogic port numbers match your configuration.
After you edit mod_wl_ohs.conf, restart the HTTP server.
Now you can access WebCenter using the HTTP port; for example,
http://denptw21.mlab.jdedwards.com:7777/webcenter
If you added (optional) the domain console and enterprise manager connections, then the HTTP URL will be:
http://denptw21.mlab.jdedwards.com:7777/console
http://denptw21.mlab.jdedwards.com:7777/em
You must register the WebGate Agent for WebCenter Spaces.
Install and configure Oracle HTTP Server and WebGate.
Install and configure OID and OAM Server.
Install and configure Oracle WebCenter Spaces.
Use these steps to register the WebGate Agent.
Open an internet browser and connect to Oracle Access Manager.
Open the OAM console.
http://oamserver:oamport/oamconsole
Enter the Admin user and Password.
Select New OAM 11g Webgate option.
Enter a WebGate agent name and select the Open security option.
Enter your WebCenter URL in Base URL.
Click Apply to create the agent. Authorization and authentication policies will be created.
A Host Identifier and an Application Domain is generated as well.
Create the Resource URL from the Resources option
Click the Create button
Enter the following information:
Type = HTTP
Host Identifier = Select your Host Identifier
Resource URL = /webcenter
Protection Level = Protected
Authentication Policy = Protected Resource Policy
Authorization Policy = Protected Resource Policy
Repeat the above step and add the resource URL = /console and /em (if you plan to use SSO on the Admin Console and Enterprise Manager.)
Double-click the Protected Resource Policy.
You should see the newly added resources listed.
Review all registered agents.
Select the System Configuration tab.
Open the Access Manager Settings section and open the SSO Agents option.
Double-click OAM Agents, and then click the Search button.
The system displays a list of registered agents.
The agent registration creates a cwallet.sso and ObAccessClient.xml file.
Copy these two files to the WebCenter server:
<MW_HOME>/user_projects/domain/OAMDomain/output/<Agent_name> location
<MW_Home>Oracle_WT1/instances/instance1/config/OHS/ohs1/webgate/config directory
A system property tells WebCenter that the application is configured in SSO mode and some special handling is required.
To set this property, edit the setDomainEnv.sh (.cmd) script located in your <domain>/bin directory, and add an entry similar to the following at the end of the file:
EXTRA_JAVA_PROPERTIES="-Doracle.webcenter.spaces.osso=true ${EXTRA_JAVA_PROPERTIES}"
export EXTRA_JAVA_PROPERTIES
After changing the property, restart all the WebCenter Services: Admin Server, WC_Spaces server.
Stop and restart the Oracle HTTP server process using OPMN:
On Windows, open the Windows Services and stop and restart the Oracle HTTAP server process.
On Unix/Linux, go to <MW_Home>/<oid_instance_name>/bin and enter these commands:
./opmnctl stopall
./opmnctl startall
Test your SSO with the WebCenter URL:
The SSO process switches to the Oracle Access Manager and display the SSO page.
Log in with your WebCenter user name and password.
