Skip Navigation Links
Exit Print View
Oracle® ZFS Storage Appliance Administration Guide
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 Oracle ZFS Storage Appliance Overview
Chapter 2 Status
Chapter 3 Initial Configuration
Chapter 4 Network Configuration
Chapter 5 Storage Configuration
Chapter 6 Storage Area Network Configuration
Chapter 7 User Configuration
Chapter 8 Setting ZFSSA Preferences
Chapter 9 Alert Configuration
Chapter 10 Cluster Configuration
Chapter 11 ZFSSA Services
Chapter 12 Shares, Projects, and Schema
Understanding Shares
Storage Pools
Using Shares
Share Properties
Share Snapshots
Share Clones
Shares Space Management
Shares Space Terminology
Understanding Snapshots
File System and Project Settings
Data Quotas
Data Reservations
Space Management for Replicating LUNs
User and Group Settings
Viewing Current Usage
Viewing Current Usage in the BUI
Viewing Current Usage in the CLI
Setting User or Group Quotas
Set User or Group Quotas Using the BUI
Set User or Group Quotas Using the CLI
Identity Management
Filesystem Namespace
Namespace Nested Mountpoints
Namespace Protocol Access to Mountpoints
Namespace NFSv2 / NFSv3
Namespace NFSv4
Namespace SMB
Namespace FTP / FTPS / SFTP
Namespace HTTP / HTTPS
Shares > Shares
Working with Shares > Shares in the BUI
List of Shares
Editing a Share
Usage Statistics
Static Properties
Shares Project Panel
Creating a Share
Working with Shares > Shares in the CLI
Navigation
Share Operations
Shares > Shares CLI Properties
Shares > Shares > General - BUI Page
Space Usage
Volume Size
Thin Provisioned
Mountpoint
Read only
Update access time on read
Non-blocking mandatory locking
Data deduplication
Data compression
Checksum
Cache Device Usage
Synchronous Write Bias
Database Record Size
Additional Replication
Virus Scan
Prevent Destruction
Restrict Ownership Change
Custom Properties
Shares > Shares > Protocols - BUI Page
Shares Protocols
Share Protocols - NFS
Share Protocols - CLI
Security Modes
Character Set Encodings
Shares - SMB
Shares - iSCSI
Shares - HTTP
Shares - FTP
Shares - SFTP
Shares > Shares > Access
Access Control
Shares - Root Directory Access
Shares - User
Shares - Group
Shares - Permissions
Shares - ACL Behavior
ACL Behavior on Mode Change
ACL Inheritance Behavior
Root Directory ACL
Shares - Snapshots
Shares - Snapshot Properties
.zfs/snapshot visible
Scheduled Snapshot Label
Listing Snapshots Using the BUI
Manual Snapshots Using the BUI
Create a project level snapshot
Create a share/LUN level snapshot
Renaming a Snapshot (BUI)
Destroying a Snapshot (BUI)
Rolling back to a Snapshot (BUI)
Cloning a Snapshot (BUI)
Scheduled Snapshots Using the BUI
Manual Snapshots Using the CLI
Listing Snapshots (CLI)
Taking Manual Snapshots (CLI)
Renaming a Snapshot (CLI)
Destroying a Snapshot (CLI)
Rolling back to a Snapshot (CLI)
Cloning a Snapshot (CLI)
Listing Dependent Clones Using the CLI
Scheduled Snapshots Using the CLI
Setting the Scheduled Snapshot Label Using the CLI
Projects
Working with Projects Using the BUI
Project Fields
Editing a Project
Usage Statistics
Static Properties
Creating Projects
Working with Projects Using the CLI
Navigation
Project Operations
Selecting a Pool in a Cluster
Project Properties
Project - General
Project - General Properties
Project - Space Usage
Project - Quota
Project - Reservation
Project - Inherited Properties
Project - Custom Properties
Filesystem Creation Defaults
LUN Creation Defaults
Project Protocols
Project Access
Project Snapshots
Project Snapshot Properites
Schemas
Customized Share Properties
Working with Schemas in the BUI
Configuring a Schema Using the BUI
Working with Schemas Using the CLI
Configuring a Schema Using the CLI
Chapter 13 Replication
Chapter 14 Shadow Migration
Chapter 15 CLI Scripting
Chapter 16 Maintenance Workflows
Chapter 17 Integration
Index
Data compression
Controls whether data is compressed before being written to disk. Shares can optionally compress data before writing to the storage pool. This allows for much greater storage utilization at the expense of increased CPU utilization. By default, no compression is done. If the compression does not yield a minimum space savings, it is not committed to disk to avoid unnecessary decompression when reading back the data. Before choosing a compression algorithm, it is recommended that you perform any necessary performance tests and measure the achieved compression ratio.
BUI value
CLI value
Description
Off
off
No compression is done
LZJB (Fastest)
lzjb
A simple run-length encoding that only works for sufficiently simple inputs, but doesn't consume much CPU.
GZIP-2 (Fast)
gzip-2
A lightweight version of the gzip compression algorithm.
GZIP (Default)
gzip
The standard gzip compression algorithm.
GZIP-9 (Best Compression)
gzip-9
Highest achievable compression using gzip. This consumes a significant amount of CPU and can often yield only marginal gains.
