Skip Navigation Links
Exit Print View
Oracle® ZFS Storage Appliance Administration Guide
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 Oracle ZFS Storage Appliance Overview
Chapter 2 Status
Chapter 3 Initial Configuration
Chapter 4 Network Configuration
Chapter 5 Storage Configuration
Chapter 6 Storage Area Network Configuration
Chapter 7 User Configuration
Chapter 8 Setting ZFSSA Preferences
Chapter 9 Alert Configuration
Chapter 10 Cluster Configuration
Chapter 11 ZFSSA Services
Chapter 12 Shares, Projects, and Schema
Understanding Shares
Storage Pools
Using Shares
Share Properties
Share Snapshots
Share Clones
Shares Space Management
Shares Space Terminology
Understanding Snapshots
File System and Project Settings
Data Quotas
Data Reservations
Space Management for Replicating LUNs
User and Group Settings
Viewing Current Usage
Viewing Current Usage in the BUI
Viewing Current Usage in the CLI
Setting User or Group Quotas
Set User or Group Quotas Using the BUI
Set User or Group Quotas Using the CLI
Identity Management
Filesystem Namespace
Namespace Nested Mountpoints
Namespace Protocol Access to Mountpoints
Namespace NFSv2 / NFSv3
Namespace NFSv4
Namespace SMB
Namespace FTP / FTPS / SFTP
Namespace HTTP / HTTPS
Shares > Shares
Working with Shares > Shares in the BUI
List of Shares
Editing a Share
Usage Statistics
Static Properties
Shares Project Panel
Creating a Share
Working with Shares > Shares in the CLI
Navigation
Share Operations
Shares > Shares CLI Properties
Shares > Shares > General - BUI Page
Space Usage
Volume Size
Thin Provisioned
Mountpoint
Read only
Update access time on read
Non-blocking mandatory locking
Data deduplication
Data compression
Checksum
Cache Device Usage
Synchronous Write Bias
Database Record Size
Additional Replication
Virus Scan
Prevent Destruction
Restrict Ownership Change
Custom Properties
Shares > Shares > Protocols - BUI Page
Shares Protocols
Share Protocols - NFS
Share Protocols - CLI
Security Modes
Character Set Encodings
Shares - SMB
Shares - iSCSI
Shares - HTTP
Shares - FTP
Shares - SFTP
Shares > Shares > Access
Access Control
Shares - Root Directory Access
Shares - User
Shares - Group
Shares - Permissions
Shares - ACL Behavior
ACL Behavior on Mode Change
ACL Inheritance Behavior
Root Directory ACL
Shares - Snapshots
Shares - Snapshot Properties
.zfs/snapshot visible
Scheduled Snapshot Label
Listing Snapshots Using the BUI
Manual Snapshots Using the BUI
Create a project level snapshot
Create a share/LUN level snapshot
Renaming a Snapshot (BUI)
Destroying a Snapshot (BUI)
Rolling back to a Snapshot (BUI)
Cloning a Snapshot (BUI)
Scheduled Snapshots Using the BUI
Manual Snapshots Using the CLI
Listing Snapshots (CLI)
Taking Manual Snapshots (CLI)
Renaming a Snapshot (CLI)
Destroying a Snapshot (CLI)
Rolling back to a Snapshot (CLI)
Cloning a Snapshot (CLI)
Listing Dependent Clones Using the CLI
Scheduled Snapshots Using the CLI
Setting the Scheduled Snapshot Label Using the CLI
Projects
Working with Projects Using the BUI
Project Fields
Editing a Project
Usage Statistics
Static Properties
Creating Projects
Working with Projects Using the CLI
Navigation
Project Operations
Selecting a Pool in a Cluster
Project Properties
Project - General
Project - General Properties
Project - Space Usage
Project - Quota
Project - Reservation
Project - Inherited Properties
Project - Custom Properties
Filesystem Creation Defaults
LUN Creation Defaults
Project Protocols
Project Access
Project Snapshots
Project Snapshot Properites
Schemas
Customized Share Properties
Working with Schemas in the BUI
Configuring a Schema Using the BUI
Working with Schemas Using the CLI
Configuring a Schema Using the CLI
Chapter 13 Replication
Chapter 14 Shadow Migration
Chapter 15 CLI Scripting
Chapter 16 Maintenance Workflows
Chapter 17 Integration
Index
This setting controls the behavior when servicing synchronous writes. By default, the system optimizes synchronous writes for latency, which leverages the log devices to provide fast response times. In a system with multiple disjointed filesystems, this can cause contention on the log devices that can increase latency across all consumers. Even with multiple filesystems requesting synchronous semantics, it may be the case that some filesystems are more latency-sensitive than others.
A common case is a database that has a separate log. The log is extremely latency sensitive, and while the database itself also requires synchronous semantics, it is heavier bandwidth and not latency sensitive. In this environment, setting this property to 'throughput' on the main database while leaving the log filesystem as 'latency' can result in significant performance improvements. This setting will change behavior even when no log devices are present, though the effects may be less dramatic.
The Synchronous write bias setting can be bypassed by the Oracle Intelligent Storage Protocol. Instead of using the write bias defined in the file system, the Oracle Intelligent Storage Protocol can use the write bias value provided by the Oracle Database NFSv4 client. The write bias value sent by the Oracle Database NFSv4 client is used only for that write request. For more information, see Oracle Intelligent Storage Protocol .
BUI value
CLI value
Description
Latency
latency
Synchronous writes are optimized for latency, leveraging the dedicated log device(s), if any.
Throughput
throughput
Synchronous writes are optimized for throughput. Data is written to the primary data disks instead of the log device(s), and the writes are performed in a way that optimizes for total bandwidth of the system.
