Embedded Host Driver Activation Method
Embedded host drivers occur when the Oracle Virtual Networking host driver is no
longer a stand-alone RPM that you install. Instead, the host driver is built into
the OS itself. In this situation, the host driver does not need to be installed, but
rather activated within the OS.
Table 3 Embedded Host Driver Information
Oracle Linux 5.10 (UEK2 kernel)
kernel-uek-2.6.39-400.209.1.el5uek.x86_64
Yes. Use the user package to enable the Oracle Virtual
Networking service on the host.
Oracle Linux 6.5 Update 1 (UEK3 kernel)
kernel-uek-3.8.13-22.el6uek.x86_64
Yes. Use the orclovn-user package to enable
the Oracle Virtual Networking service on the host.
Oracle Linux 7.0 (UEK3 kernel)
kernel-uek-3.8.13-35.2.1.el7uek.x86_64
Oracle VM 3.3.1 (UEK3 kernel)
kernel-uek-3.8.13-26.4.2.el6uek.x86_64
With the embedded host drivers, you do not need to upgrade, because the host
drivers are already in the server OS. As a result, you only need to install the user
space package to start or enable the services at boot time.
For information about installing and activating embedded host drivers, see Activating the Integrated Kernel.
