Skip Navigation Links
Exit Print View
Oracle Switch ES1-24
Service Manual
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Detecting and Managing Faults
Front Panel LEDs
Rear Panel LEDs
Check Switch Status (LEDs)
Sensors Overview
Check Switch Status (Oracle ILOM)
Component Sensor Targets
Motherboard Sensor Targets
Preparing for Service
ESD Precautions
Tools Needed for Service
Replaceable Components
Remove the Front Support and Air Duct
Remove the CMA
Install the CMA
Servicing Power Supplies
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing the Fan Module
Remove the Fan Module
Install the Fan Module
Glossary
Index
image:Figure shows the replaceable components.
Description
Links
1
Fan module (one)
2
Power supplies (two)
Related Information
