Use this procedure to identify the network resources and VLAN tags for each network. Both administrators and users can perform this task.
The networks listed in the top table are the initial networks that were created when SuperCluster was installed. You cannot change these networks.
The second table displays the additional networks that were added to provide network resources for I/O Domains. Users with the administrator role can add to and edit these networks. See Add or Edit a Network (Administrators).
Multiple networks can exist for a given network type. For example, you can configure two management and two client networks.
Add or edit a network – See Add or Edit a Network (Administrators).
Go to the Administrative Task Overview – See Administrative Task Overview.
Add users – See Managing User Accounts.
