Go to main content
Oracle I/O Domain Administration Guide
Exit Print View
Updated: August 2019
Monitor Current Activity
  1. Access the SuperCluster Virtual Assistant.
    See Log In to the SuperCluster Virtual Assistant.
  2. In the navigation panel, select Queue (or Deployment Queue for earlier assistant versions).
    image:A screen shot showing the queue screen.
    In this screen you can view the I/O Domains that are in the queue for deployment and the state of the deployment:
    • Currently Deploying
    • Deployment Complete
    • Reread
    • Queued for Deployment
    • Saving LDom Configuration
    • (Version 3.0) I/O Domain deletions
    • (Version 3.0) Freeze and thaw operations
    If multiple I/O Domains were deployed at the same time, they are grouped into one batch ID.
    The Resource Alteration Queue displays the state and owner of I/O Domains that in the process of resource changes, or have pending changes (see Increase or Decrease I/O Domain Resources).
  3. Click I/O Domain name to view the I/O Domain details.
  4. Consider your next action.
