Go to main content
Oracle® Exadata Storage Server X5-2 High Capacity Installation Guide
Exit Print View
Updated: July 2018
Rackmount Kit Contents
The rackmount kit contains two slide-rails, two mounting brackets, and optional securing screws.
Note -  Refer to the rackmount kit installation card for simplified instructions about installing your storage server into a four-post rack, using the slide-rail and cable management arm options.
image:Figure showing the contents of the tool-less rackmount kit.
Call Out
Description
1
Slide-rails
2
Mounting brackets
3
Four M4 x 5 fine-pitch mounting bracket securing screws (not used)
4
Installation card
Related Information
