Oracle® SuperCluster M6-32 Owner's Guide: Administration
Exit Print View
Updated: December 2015
ASR Installation Overview
This is a high-level description of the tasks you perform to configure ASR on SuperCluster. For more details, refer to ASR documentation. See ASR Resources.
  1. Create or verify your MOS account at http://support.oracle.com.
    Ensure that your MOS account is correctly set up:
    • Oracle Premier Support for Systems or Oracle/Sun Limited Warranty
    • Technical contact responsible for SuperCluster system
    • Valid shipping address for parts
  2. Designate a standalone system to serve as the ASR Manager and install the ASR Manager software.
    The server must run either Oracle Solaris or Linux, and Java
    You must have superuser access to the ASR Manager system.
    To download ASR Manager software, go to:http://www.oracle.com/technetwork/systems/asr/downloads
    For installation instructions, refer to the ASR documentation that corresponds to the version of ASR Manager you plan to install. The documentation is available at:
    http://docs.oracle.com/cd/E37710_01/index.htm
  3. Ensure that the ASR Manager server has connectivity to the Internet using HTTPS.
    You might need to open certain ports to your datacenter. For more information, see the Oracle ASR Security White paper, located here:
  4. (Optional) Obtain these documents:
    • Oracle SuperCluster M6-32 System Site Checklists
    • Oracle SuperCluster M6-32 System Configuration Worksheets
    The information in these documents can provide helpful information when you configure SuperCluster for ASR.
  5. Configure and activate SuperCluster ASR assets.
    Refer to ASR documentation and see Configuring ASR on the Compute Servers (Oracle Solaris 11).
    Note -  An active ASR Manager must be installed and running before you configure ASR assets.
    Note -  To monitor Oracle Solaris 10 assets, you must install the latest STB bundle on SuperCluster. Refer to Doc ID 1153444.1 to download the latest STB bundle from MOS: https://support.oracle.com
  6. Approve ASR assets in MOS.
    Follow the instructions in the ASR documentation.
