Oracle® SuperCluster M6-32 Owner's Guide: Administration
Exit Print View
Updated: December 2015
Cautions
The following cautions apply to SuperCluster M6-32.
Caution
Caution  -  Do not touch the parts of this product that use high-voltage power. Touching them might result in serious injury.
Caution
Caution  -  Keep the front and rear cabinet doors closed. Failure to do so might cause system failure or result in damage to hardware components.
Caution
Caution  -  Keep the top, front, and back of the cabinets clear to allow proper airflow and prevent overheating of components.
Use only the supplied hardware.
