Perform this task after completing these tasks:
For more information on the process, see ASR MOS 5.3+ Activation Process (Doc ID 1329200.1).
list_asset
The ASR assets in your SuperCluster system are listed, including compute servers, storage servers, and ZFS storage controllers.
A complete list of all qualified ASR assets that are awaiting approval are displayed.
By default, all support identifiers that you are associated with are displayed. If this list of assets is long, you can limit the display to show only assets associated to one support identifier. You can also search for an asset's serial number.
If there is any missing asset information the ASR Activation window is displayed, prompting you to enter the missing information.
Required fields for ASR asset activation are:
Contact Name: You can only select a name associated with the support identifier. Click the drop-down menu to see the list of available names.
A contact must have the Create SR privilege for the asset's support identifier.
Street Address 1: Type the street address for the asset.
Country: Select the asset's country location from the drop-down menu.
ZIP/Postal Code: type the ZIP/postal code for the asset's location. If there is no postcode insert "-".
Distribution Email List: Add email addresses that receive all ASR mail notifications. Separate multiple email addresses with a comma. For example:
asr-notifications-1@mycompany.com, asr-notifications-2@mycompany.com
ASR sends email to the Contact's email address and the Distribution Email List, if provided. This is a useful feature if your organization has a team that should be informed about Service Requests created by ASR.
# asradm send test email-address@company.com
This command sends a test alert e-mail to the e-mail address.
