The following table lists procedures about how to maintain public network hardware.
Physically adding public network adapters to a node in a cluster is no different from adding public network adapters in a noncluster environment. For the procedure about how to add public network adapters, see the hardware documentation that shipped with your node and public network adapters.
Once the adapters are physically installed, Oracle Solaris Cluster requires that they be configured in an IPMP group.
If your network uses jumbo frames, review the requirements in Public Network Hardware: Requirements When Using Jumbo Frames and see the documentation that shipped with your network interface card for information about how to configure jumbo frames.
To add a new public network adapter to an IPMP group, see Chapter 1, Administering TCP/IP Networks in Administering TCP/IP Networks, IPMP, and IP Tunnels in Oracle Solaris 11.3.
For cluster-specific commands and guidelines about how to replace public network adapters, see Administering the Public Network in Oracle Solaris Cluster 4.3 System Administration Guide.
For procedures about how to administer public network connections, see the Chapter 2, About IPMP Administration in Administering TCP/IP Networks, IPMP, and IP Tunnels in Oracle Solaris 11.3.
For the procedure about removing public network adapters, see the hardware documentation that shipped with your node and public network adapters.
To add the new public network adapter to a IPMP group, see the Oracle Solaris Cluster 4.3 System Administration Guide.
For cluster-specific commands and guidelines about how to remove public network adapters, see the Oracle Solaris Cluster 4.3 System Administration Guide.
For the procedure about how to remove public network adapters, see the hardware documentation that shipped with your node and public network adapters.
