Dual-Switch
Configuration
This example shows a dual-switch configuration, with the servers
configured in between the two switches as the "bump". Each server
is dual-homed. LBGs are formed in a symmetric way (LBG on each switch
has the same port members set up in the exact same order).
Group ID |
1 |
Switch port for server 1 |
extreme-ethernet 0/15 on switch 2 |
Switch port for server 2 |
extreme-ethernet 0/16 on switch 2 |
Switch port for server 3 |
extreme-ethernet 0/17 on switch 2 |
Switch port for server 4 |
extreme-ethernet 0/18 on switch 2 |
