Configure accept-mode to be able to respond to ping, traceroute, and telnet commands destined for virtual IPv4 and IPv6 address of VRRP.
The ES1-24p-2 switch, which is now the backup becomes the master.
ES1-24p-1 SEFOS# configure terminal ES1-24p-1 SEFOS(config)# interface vlan 100 ES1-24p-1 SEFOS(config-if)# shutdown ES1-24p-1 SEFOS(config-if)# end ES1-24p-2 SEFOS# show vrrp P indicates configured to preempt Interface vrID Prio P State Master Address VRouter Address --------- ---- ---- - ----- ------------------------- ------------------------- vlan100 1 150 P Master 192.168.100.10 192.168.100.1 vlan100 1 150 P Master fe80::210:e0ff:fe2a:fd41 fe80::210:e0ff:fe2c:fd21 ES1-24p-1 SEFOS# show vrrp P indicates configured to preempt Interface vrID Prio P State Master Address VRouter Address --------- ---- ---- - ----- ------------------------- ------------------------- vlan100 1 200 P Init - 192.168.100.1 vlan100 1 200 P Init - fe80::210:e0ff:fe2c:fd21
Host-2# ping 1000::5 Host-2# ping 192.168.100.1
ES1-24p-2 SEFOS# configure terminal ES1-24p-2 SEFOS(config)# router vrrp ES1-24p-2 SEFOS(config-vrrp)# vrrp version v3 ES1-24p-2 SEFOS(config-vrrp)# interface vlan 100 ES1-24p-2 SEFOS(config-vrrp-if)# vrrp 1 ipv4 accept-mode enable ES1-24p-2 SEFOS(config-vrrp-if)# vrrp 1 ipv6 accept-mode enable ES1-24p-2 SEFOS(config-vrrp-if)# end
