CLI Command
Modes
The following table lists the configuration modes used in
this document with their access and exit methods.
User EXEC |
Access SEFOS from Oracle ILOM with read-only
rights (privilege level 1). |
SEFOS> |
Use logout or exit to return to the Oracle
ILOM prompt. |
Privileged EXEC |
Access SEFOS from Oracle ILOM with full
administrative rights (privilege level 15). |
SEFOS# |
Use the logout or exit command
to return to the Oracle ILOM prompt. |
Global Configuration |
From User EXEC mode, use the enable command. |
SEFOS(config)# |
Use the end command
to return to Privileged EXEC mode. |
Interface Configuration |
From Global Configuration mode, use the interface interface-type interface-id command. |
SEFOS(config-if)# |
Use the exit command
to return to Global Configuration mode, or use the end command
VRRP Router Configuration |
From Global Configuration mode, use the router VRRP command. |
SEFOS(config-vlan)# |
VRRP Interface Configuration |
From VRRP Router Configuration mode,
use the command interface vlan vlan-id command. |
SEFOS(config-vrrp-if)# |
