ES1-24p-1 SEFOS# configure terminal ES1-24p-1 SEFOS(config)# set gvrp disable ES1-24p-1 SEFOS(config)# set gmrp disable ES1-24p-1 SEFOS(config)# set port-channel enable ES1-24p-1 SEFOS(config)# interface vlan 1 ES1-24p-1 SEFOS(config-if)# shutdown ES1-24p-1 SEFOS(config-if)# no ip address ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# shutdown spanning-tree ES1-24p-1 SEFOS(config)# interface range extreme-ethernet 0/1-24 ES1-24p-1 SEFOS(config-if-range)# shutdown ES1-24p-1 SEFOS(config-if-range)# end
You must add at least one port to the VLAN before you can assign the VLAN name.
ES1-24p-1 SEFOS# configure terminal ES1-24p-1 SEFOS(config)# vlan 20 ES1-24p-1 SEFOS(config-vlan)# ports add extreme-ethernet 0/23 untagged extreme-ethernet 0/23 ES1-24p-1 SEFOS(config-vlan)# vlan active ES1-24p-1 SEFOS(config-vlan)# exit ES1-24p-1 SEFOS(config)# vlan 100 ES1-24p-1 SEFOS(config-vlan)# ports add extreme-ethernet 0/4,0/20 untagged extreme-ethernet 0/4,0/20 ES1-24p-1 SEFOS(config-vlan)# vlan active ES1-24p-1 SEFOS(config-vlan)# exit ES1-24p-1 SEFOS(config)# end
ES1-24p-1 SEFOS# configure terminal ES1-24p-1 SEFOS(config)# interface extreme-ethernet 0/4 ES1-24p-1 SEFOS(config-if)# description connected to Host-2 01” ES1-24p-1 SEFOS(config-if)# switchport pvid 100 ES1-24p-1 SEFOS(config-if)# no shutdown ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# interface extreme-ethernet 0/20 ES1-24p-1 SEFOS(config-if)# description connected to ES1-24p-2 ES1-24p-1 SEFOS(config-if)# switchport acceptable-frame-type untaggedAndPrioritytagged ES1-24p-1 SEFOS(config-if)# switchport pvid 100 ES1-24p-1 SEFOS(config-if)# no shutdown ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# interface extreme-ethernet 0/23 ES1-24p-1 SEFOS(config-if)# description "connected to ToR72p-1 on port61" ES1-24p-1 SEFOS(config-if)# switchport acceptable-frame-type untaggedAndPrioritytagged ES1-24p-1 SEFOS(config-if)# switchport pvid 20 ES1-24p-1 SEFOS(config-if)# no shutdown ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# end
ES1-24p-1 SEFOS# configure terminal ES1-24p-1 SEFOS(config)# interface vlan 20 ES1-24p-1 SEFOS(config-if)# ip address 192.168.20.20 255.255.255.0 ES1-24p-1 SEFOS(config-if)# ipv6 enable ES1-24p-1 SEFOS(config-if)# ipv6 address 2000::20 112 unicast ES1-24p-1 SEFOS(config-if)# no shutdown ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# interface vlan 100 ES1-24p-1 SEFOS(config-if)# ip address 192.168.100.20 255.255.255.0 ES1-24p-1 SEFOS(config-if)# ip address 192.168.101.20 255.255.255.0 secondary ES1-24p-1 SEFOS(config-if)# ip address 192.168.102.20 255.255.255.0 secondary ES1-24p-1 SEFOS(config-if)# ipv6 enable ES1-24p-1 SEFOS(config-if)# ipv6 address 1000::20 112 unicast ES1-24p-1 SEFOS(config-if)# ipv6 address 1100::20 112 unicast ES1-24p-1 SEFOS(config-if)# ipv6 address 1200::20 112 unicast ES1-24p-1 SEFOS(config-if)# no shutdown ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# end
VRRP versions supported are V2 and V3. V2-V3 is an intermediate version used only to migrate from V2 to V3.
The following commands are explained with an example in Master Election Based on IP Address, Master Election Based on Priority, and Configure Accept-mode sections.
ES1-24p-1 SEFOS(config)# router vrrp
ES1-24p-1 SEFOS(config-vrrp)# vrrp version ?
VRRP commands :
vrrp version { v2 | v2-v3 | v3 }
ES1-24p-1 SEFOS(config-vrrp)# vrrp version v3
ES1-24p-1 SEFOS(config-vrrp)# end
ES1-24p-1 SEFOS(config-vrrp-if)# vrrp 1 ipv4 192.168.100.1
ES1-24p-1 SEFOS(config-vrrp-if)# vrrp 1 ipv4 priority 200
ES1-24p-1 SEFOS(config-vrrp-if)# vrrp 1 ipv4 timer msec 2000
ES1-24p-1 SEFOS(config-vrrp-if)# vrrp 1 ipv4 accept-mode enable
ES1-24p-1 SEFOS(config-vrrp-if)# vrrp 1 ipv6 fe80::210:e0ff:fe2c:fd21
ES1-24p-1 SEFOS(config-vrrp-if)# vrrp 1 ipv6 1000::5 secondary
ES1-24p-1 SEFOS(config-vrrp-if)# vrrp 1 ipv6 1100::5 secondary
ES1-24p-1 SEFOS(config-vrrp-if)# vrrp 1 ipv6 1200::5 secondary
ES1-24p-1 SEFOS(config-vrrp-if)# vrrp 1 ipv6 priority 200
ES1-24p-1 SEFOS(config-vrrp-if)# vrrp 1 ipv6 timer msec 2000
ES1-24p-1 SEFOS(config-vrrp-if)# vrrp 1 ipv6 accept-mode enable
ES1-24p-1 SEFOS(config-vrrp-if)# end
ES1-24p-1 SEFOS# copy run start Building configuration ... [OK]
