The SP must have a valid IP address configured on its management interface.
ORACLESP-AKCH444444 login: root changeme>Password: password configured by the admin or the default password Hostname: ORACLESP-AKCH444444 ->
DHCP is enabled by default, so the host can get the network configuration automatically if there is a DHCP server on the network.
The names and addresses in the following examples are only for demonstration.
-> cd /SP/network /SP/network -> show /SP/network Targets: ipv6 test Properties: commitpending = (Cannot show property) dhcp_clientid = none dhcp_server_ip = 10.134.178.5 ipaddress = 10.134.178.170 ipdiscovery = dhcp ipgateway = 10.134.178.1 ipnetmask = 255.255.255.0 macaddress = 00:21:28:79:8B:58 pendingipaddress = 10.134.178.170 pendingipdiscovery = dhcp pendingipgateway = 10.134.178.1 pendingipnetmask = 255.255.255.0 pendingvlan_id = (none) state = enabled
-> set pendingipaddress=10.134.178.170 Set 'pendingipaddress' to '10.134.178.170' -> set pendingipnetmask=255.255.255.0 Set 'pendingipnetmask' to '255.255.255.0' -> set pendingipgateway=10.134.178.1 Set 'pendingipgateway' to '10.134.178.1' -> set pendingipdiscovery=static Set 'pendingipdiscovery' to 'static' -> set commitpending=true Set 'commitpending' to 'true' -> show /SP/network Targets: ipv6 test Properties: commitpending = (Cannot show property) dhcp_clientid = none dhcp_server_ip = none ipaddress = 10.134.178.170 ipdiscovery = static ipgateway = 10.134.178.1 ipnetmask = 255.255.255.0 macaddress = 00:21:28:79:8B:58 pendingipaddress = 10.134.178.170 pendingipdiscovery = static pendingipgateway = 10.134.178.1 pendingipnetmask = 255.255.255.0 pendingvlan_id = (none) state = enabled vlan_id = (none)
