Upgrade the host at the ES2-> prompt.
Run the version command and compare the SP filesystem version to the version in the new image.
In the ES2-72_64_SEFOS_2.0.0.7.pkg, the version number is 2.0.0.7.
ES2-> version SP firmware 3.2.5.60 SP firmware build number: 100744 SP firmware date: Wed Jul 15 11:07:33 PDT 2015 SP filesystem version: 2.0.0.3
Answer the questions that appear on the screen as you proceed through the upgrade.
The following example illustrates the upgrade process using FTP from a server with an IP address of 192.168.1.100.
-> load -source ftp://username:password@192.168.1.100/ES2-72_64_SEFOS_2.0.0.7.pkg Enter remote user password: enter password NOTE: An upgrade takes several minutes to complete. ILOM will enter a special mode to load new firmware. No other tasks can be performed in ILOM until the firmware upgrade is complete and ILOM is reset. Are you sure you want to load the specified file (y/n)? y Preserve existing configuration (y/n)? y Firmware update is complete. The system must be reset for the new image to be loaded. ES2-> ES2-> reset /SP Are you sure you want to reset /SP (y/n)? y Performing hard reset on /SP
ES2-> cd /SYS/fs_cli/ cd: Connecting to Fabric Switch CLI localhost SEFOS# show system information show system information Hardware Version : patch-319710_3.3.11_00306215 Firmware Version : ES2-R72-2.0.0.7 Hardware Part Number : 1-0-0 Software Serial Number : 1-0-0 Software Version : 7.3.2 Switch Name : Oracle-ES2-72 System Contact : System Location : Logging Option : Console Logging Device Uptime : 0 Days, 1 Hrs, 48 Mins, 43 Secs Login Authentication Mode : Local Config Save Status : Not Initiated Remote Save Status : Not Initiated Config Restore Status : Successful Traffic Separation Control : none
