Like the SP, the host must have a valid IP address configured on its management interface.
-> start /SYS Are you sure you want to start /SYS (y/n)? y
-> start /HOST/console Are you sure you want to start /HOST/console (y/n)? y
The switch host's Oracle ILOM login prompt appears if the host is powered on..
The default user is root. The default password is changeme. The switch Oracle ILOM prompt, ES2->, appears.
DHCP is enabled by default, so the host can get the network configuration automatically if there is a DHCP server on the network.
The names and addresses in the following examples are only for demonstration.
ES2-> cd /SP/network/
/SP/network
ES2-> show
/SP/network
Targets:
ipv6
test
Properties:
commitpending = (Cannot show property)
dhcp_clientid = none
dhcp_server_ip = 10.134.178.5
ipaddress = 10.134.178.167
ipdiscovery = dhcp
ipgateway = 10.134.178.1
ipnetmask = 255.255.255.0
macaddress = 00:19:0F:16:D4:19
pendingipaddress = 10.134.178.167
pendingipdiscovery = dhcp
pendingipgateway = 10.134.178.1
pendingipnetmask = 255.255.255.0
state = enabled
vlan_id = (none)
Commands:
cd
set
show
ES2-> set pendingipaddress=10.134.178.167
Set 'pendingipaddress' to '10.134.178.167'
ES2-> set pendingipnetmask=255.255.255.0
Set 'pendingipnetmask' to '255.255.255.0'
ES2-> set pendingipgateway=10.134.178.1
Set 'pendingipgateway' to '10.134.178.1'
ES2-> set pendingipdiscovery=static
Set 'pendingipdiscovery' to 'static'
ES2-> set commitpending=true
Set 'commitpending' to 'true'
ES2-> show
/SP/network
Targets:
ipv6
test
Properties:
dhcp_server_ip = none
ipdiscovery = static
macaddress = 00:19:0F:14:2F:BD
pendingipaddress = 10.134.178.170
pendingipdiscovery = static
pendingvlan_id = (none)
state = enabled
vlan_id = (none)
