Cannot perform power cycle of host from SP via Oracle ILOM web interface (20766502)
Workaround — Do not use Power Cycle. Use Power Off, followed by Power On. .
Incorrect processor data on System Information Processors screen under SP Oracle ILOM (20766289).
Workaround — None.
snmp properties changes do not take affect without a servicestate toggle (20823021).
Workaround — Disable and then enable servicestate.
-> set servicestate=disabled Set 'servicestate' to 'disabled' . -> set servicestate=enabled Set 'servicestate' to 'enabled'
Superfluous trap when snmp agent is restarted on the host Oracle ILOM (20823179).
Workaround — None.
snmp write returns incorrect message when set as read-only on the host Oracle ILOM (20816876).
snmpset returns a value of noAccess instead of notWritable.
Workaround — None.
/SP/clock timezone displayed incorrectly on ILOM host (20815455).
The clock timezone can be set correctly on the SP, but not on the host.
Workaround — None.
snmp write data does not show up under the host Oracle ILOM CLI (20808643).
Edits to snmp values may be successful on the SP but not on the host.
Workaround — None.
Alertmgmt test rule does not generate a trap (20807736).
When an snmp manager is set up to receive traps from the host Oracle ILOM and a testrule is performed to test the connection, traps are generated on the SP but not on the host.
Workaround — None.
Error when attempting to walk sefos mibs on host and mib data missing (20807119).
When sefos OID is walked, it returns an error. Data might not be available afterward.
Workaround — None.
