Upgrade the SP at the -> prompt.
Compare the SP firmware build number to the build number in the new image.
In ES2-72_64_SP_3.2.5.60_r109079.pkg, the build number is r109079.
Answer the questions that appear on the screen as you proceed through the installation.
The following example illustrates the upgrade process using FTP from a server with an IP address of 192.168.1.100.
-> load -source ftp://username:password@192.168.1.100/ES2-72_64_SP_3.2.5.60_r109079.pkg Enter remote user password: enter password NOTE: An upgrade takes several minutes to complete. ILOM will enter a special mode to load new firmware. No other tasks can be performed in ILOM until the firmware upgrade is complete and ILOM is reset. Are you sure you want to load the specified file (y/n)? y Preserve existing configuration (y/n)? y .............................................................. .............................................................. .............................................................. ......... Firmware update is complete. ILOM will now be restarted with the new firmware. -> /sbin/reboot
-> version SP firmware 3.2.5.60 SP firmware build number: 109079 SP firmware date: Fri Mar 25 15:47:10 PDT 2016 SP filesystem version: 0.2.10
-> show /SP/policy/ /SP/policy Targets: Properties: HOST_AUTO_POWER_ON = disabled HOST_LAST_POWER_STATE = disabled -> set /SP/policy/ HOST_AUTO_POWER_ON=enabled Set 'HOST_AUTO_POWER_ON' to 'enabled' -> show /SP/policy/ /SP/policy Targets: Properties: HOST_AUTO_POWER_ON = enabled HOST_LAST_POWER_STATE = disabled
