Table 1-1 lists the changes in this revision of the documentation to support this release of the software.
Note: Siebel Innovation Pack 2016 is a continuation of the Siebel 8.1/8.2 release. |
Table 1-1 What's New in Siebel CRM Fundamentals Guide, Siebel Innovation Pack 2016
| Topic | Description |
"About the Fourth Level Subview Bar" |
New topic. It includes information about the fourth level subview bar. |
Modified topic. It includes information about the Send icon. |
New topic. It includes information about sending messages by using the menu toolbar. |
"About Siebel User Interface Behavior" |
New topic. It lists some issues to note about the Siebel user interface behavior. |
"Setting Up CalDAV and CardDAV Publishing " |
New topic. It describes how to set up CalDAV and CardDAV publishing for iOS and Android mobile devices. |
"About Using the Participant Availability Subview" |
Modified topic. It includes more information about the functionality in the Participant Availability Subview. |
"About Using Alarms for Activities" |
New topic. It includes information about using alarms for activities. |
"Creating Recurring Calendar Activities" |
Modified topic. It includes information about new field names. for recurring calendar activities. |
New topic. It includes information about how to activate alarms for calendars. |
"Postponing and Dismissing Alarms" |
New topic. It includes information about how to postpone and dismiss alarms for calendars. |
Modified topic. It includes more information about the navigation options in Siebel applications. |
"Activating Alarms for All Calendar Activities" |
New topic. It includes information about how to activate alarms for all calendar activities. |
"Setting Up Default Alarm Lead Times" |
New topic. It includes information about how to set up default alarm lead times in calendars |
"Setting Up Default Alarm Snooze Times" |
New topic. It includes information about how to set up default alarm snooze times in calendars. |
"Setting a User Profile Image" |
New topic. It shows you how to set a user profile image for the Siebel application, which involves uploading a user profile image to Siebel Server. |
New topic. It lists the keyboard shortcuts you can use to share information with others in Siebel CRM. |
New topic. It lists the keyboard shortcuts you can use when calling others in Siebel CRM. |
Modified topic. It includes more information the user interface areas for level bar regions. |
