Voir la section Switching Feature Topology.
Ports 1 à 4 – Connexion aux ports 1 à 4 sur le commutateur SEFOS-2
Port 25 – Connexion au serveur hôte A (adresse IP 20.0.0.10)
Port 26 – Connexion au serveur hôte B (adresse IP 20.0.0.20)
Voir la section Connect to SEFOS.
SEFOS-1# configure terminal SEFOS-1(config)# vlan 101 SEFOS-1(config-vlan)# ports xl-ethernet 0/25-26 untagged xl-ethernet 0/25-26 SEFOS-1(config-vlan)# vlan active SEFOS-1(config-vlan)# exit
SEFOS-1# configure terminal SEFOS-1(config)# interface range xl-ethernet 0/25-26 SEFOS-1(config-if-range)# switchport pvid 101 SEFOS-1(config-if-range)# no shutdown SEFOS-1(config-if-range)# exit
SEFOS-1# configure terminal SEFOS-1(config-int)# interface vlan 101 SEFOS-1(config-int)# ip address 20.0.0.1 255.0.0.0 SEFOS-1(config-int)# no shutdown SEFOS-1(config-int)# exit
SEFOS-1# show ip interface vlan1 is down, line protocol is down Internet Address is 10.0.0.1/8 Broadcast Address 10.255.255.255 vlan101 is up, line protocol is up Internet Address is 20.0.0.1/8 Broadcast Address 10.255.255.255
SEFOS-1# show interface status Port Status Duplex Speed Negotiation Capability ---- ------ ------ ----- ----------- ---------- Xl0/1 not connected Full 10 Gbps Auto-Negotiation Auto-MDIX on Xl0/2 not connected Full 10 Gbps Auto-Negotiation Auto-MDIX on ... Xl0/25 connected Full 10 Gbps Auto-Negotiation Auto-MDIX on Xl0/26 connected Full 10 Gbps Auto-Negotiation Auto-MDIX on ... SEFOS-1# show interface description Interface Status Protocol --------- ------ -------- Xl0/1 down down Xl0/2 down down ... Xl0/25 up up Xl0/26 up up ... vlan101 up up
La commande ping doit aboutir.
SEFOS-1# show mac-address-table Vlan Mac Address Type Ports ---- ----------- ---- ----- 101 00:14:4f:6c:7d:e9 Learnt Xl0/25 Total Mac Addresses displayed: 1
Pour configurer la topologie, toutes les interfaces doivent être en cours d'exécution. Sinon, utilisez la commande no shutdown pour afficher les ports.
SEFOS-1# configure terminal SEFOS-1(config)# interface range xl 0/1-2 SEFOS-1(config-if-range)# switchport pvid 101 SEFOS-1(config-if-range)# no shutdown SEFOS-1(config-if-range)# end
Sur les commutateurs, assurez-vous que les interfaces suivantes sont en cours d'exécution : 0/1, 0/2, 0/25, 0/26.
