Oracle VM Server Installation Options
You can choose to install Oracle VM Server on a single server or on multiple servers. The scope of this document is for single server Oracle VM Server installations. The table below provides some information about these two installation options.
Multiple servers
Single server
Install Oracle VM Server to a single server using one of the following methods:
Locally: Perform the Oracle VM Server installation with
physical access to the server. This option is recommended if
you have just completed the physical installation of the
server in the rack.
Remotely: Perform the Oracle VM Server installation from a
remote location. This option uses the Oracle ILOM Remote
System Console Plus application to access Oracle System
Assistant or to perform a manual Oracle VM Server
installation.
For information, see Single-Server Installation
Methods.
Single-Server Installation Methods
Select a method for providing the Oracle VM Server installation media. Use the following information to determine the local or remote Oracle VM Server installation that best meets your needs.
Local assisted Oracle VM Server installation
– Uses Oracle System Assistant.
Remote assisted Oracle VM Server installation
A remote system with a web browser, access to the Oracle VM Server installer ISO image, and network access to the server management port (NET MGT). For more information, see Assisted Oracle VM Server Installation.
Local Oracle VM Server installation
using a DVD drive – Uses a physical DVD
drive connected to the server.
Remote Oracle VM Server installation
using a DVD drive or DVD ISO image – Uses a
redirected physical DVD drive on a remote system running the
Oracle ILOM Remote System Console Plus application.
A remote system with a web browser, an attached physical DVD
drive, the Oracle VM Server installer ISO image on a DVD, and
information, see Manual Oracle VM Server Installation.
PXE Image
– Uses the server Preboot eXecution Environment (PXE) to launch the Oracle VM installer from a network interface.
A PXE server with the Oracle VM installation image.
Note -
PXE booting the Oracle VM installation image is not included in this scope of this document. For instructions on PXE booting the Oracle VM installer, refer to the Oracle VM documentation at http://docs.oracle.com/cd/E50245_01/index.html
This method involves using Oracle System Assistant. You deliver the Oracle VM
Server installation media on either a local or remote DVD drive, USB device, or DVD
image. Oracle System Assistant guides the installation process. Your server must
support Oracle System Assistant, and it must be installed in the server.
With this method, you deliver the Oracle VM Server distribution media on either a
local or remote DVD drive, USB device, or DVD image. The drivers for your server are
included with the Oracle VM Server distribution media. To install Oracle VM Server,
use the distribution media's installation wizard.
