Oracle® Server X5-8 Installation Guide for Oracle VM Server
Exit Print View
Updated: July 2015
Supported Oracle VM Server Software
The server supports the following Oracle VM Server software.
VM Software
Edition
Oracle VM Server
Release 3.3.2
If you requested that the Oracle VM Server software be preinstalled on the server when you placed your order, Oracle VM Server 3.3 was preinstalled at the factory. If the Oracle VM software is preinstalled on your server, but you do not want to use it, you can install any other supported operating system or virtual machine software on your server.
The Oracle VM Server Hardware Compatibility List (HCL) identifies hardware that is compatible with Oracle VM Server. To find the latest Oracle VM Server version supported for the Oracle Server X5-8, go to the following site and search using your server model number:
http://linux.oracle.com/pls/apex/f?p=117:1:3991604960223967
Note -  If Oracle VM Server was preinstalled, it was installed with the server set to Legacy BIOS boot mode. If you choose to boot the server in UEFI boot mode, the preinstalled image is not accessible and cannot be used. Oracle VM Server does not support UEFI boot mode.
Note -  For all late-breaking requirements for the Oracle VM Server software, refer to the latest version of the Oracle Server X5-8 Product Notes at http://www.oracle.com/goto/X5-8/docs-videos.
Related Information
