Oracle® Server X5-8 Installation Guide for Oracle VM Server
Exit Print View
Updated: July 2015
Before You Begin
Ensure that the following requirements are met:
  • You have prepared the boot environment. For more information, see Preparing the Boot Environment.
  • You have access to the host console. For more information, see Accessing the Host Console.
  • You have prepared the boot media. For more information, see Preparing the Boot Media.
  • You have selected the installation target and ensured that it is properly installed. For more information, see Preparing the Installation Target.
  • Two systems with static IP addresses have been set up:
    • One system to install Oracle VM Server.
    • One system for Oracle VM Manager with one of the following:
      • Oracle Linux 5 Update 5, 64-bit or subsequent releases
      • Oracle Linux 6, 64-bit or subsequent releases
      • Red Hat Enterprise Linux 5 Update 5, 64-bit or subsequent releases
      • Red Hat Enterprise Linux 6, 64-bit or subsequent releases
  • You have reviewed the additional preinstallation tasks and requirements in the Oracle VM Installation and Upgrade Guide for Release 3.3 at http://docs.oracle.com/cd/E50245_01/index.html.
  • You have access to the Oracle VM installation documentation. The Oracle VM Release 3.3 Documentation Library is available at http://docs.oracle.com/cd/E50245_01/index.html.
