Exit Print View
See Install the Adapter.
# scanpci|grep -i 2088 pci bus 0x0004 cardnum 0x00 function 0x00: vendor 0x108e device 0x2088
ESD Precautions
Order Additional Hardware
Cable Cautions
Install the Adapter
Standard MT and PrizmMT MPO Cables
Install a PrizmMT Cable
Clean The PrizmMT Receptacle or Connector Ferrule
Verify the Adapter Installation (Oracle Linux)
Remove the Adapter
Remove a PrizmMT Cable
