Oracle Quad 10 Gb or Dual 40 Gb Ethernet Adapter User's Guide
Exit Print View
Updated: June 2016
Configure VXLANs (Oracle Solaris)
VXLAN is a Layer 2 technology that enables you to create a Layer 2 network on top of a Layer 3 network, thereby providing further network isolation. VXLAN provides a virtual Layer 2 network that stretches over multiple physical Layer 2 networks. Provisioning resources in a cloud environment is not restricted to a single physical Layer 2 network. Physical servers can be a part of an VXLAN network, as long as they are connected by IPv4 or IPv6 networks.
  1. Determine the types of links that are used in the system.
    # dladm show-phys | grep i40e
    net4              Ethernet             up         10000  full      i40e0
    net6              Ethernet             up         10000  full      i40e2
    net5              Ethernet             up         10000  full      i40e1
    net7              Ethernet             up         10000  full      i40e3
  2. Create an IP interface over the VXLAN.
    # dladm create-vxlan -p addr=10.10.10.1,vni=100 vxlan1
    # dladm create-vxlan -p addr=10.10.10.1,vni=101 vxlan2
  3. Verify the VXLAN configuration.
    # dladm show-vxlan
    LINK                ADDR                     VNI   MGROUP
    vxlan1              10.10.10.1               100   224.0.0.1
    vxlan2              10.10.10.1               101   224.0.0.1
Related Information
