Oracle Quad 10 Gb or Dual 40 Gb Ethernet Adapter User's Guide
Exit Print View
Updated: June 2016
Configure VLANs (Linux)
  1. Ensure that the i40e module is loaded.
    # modprobe i40e
  2. Plumb the adapter's interface.
    # ifconfig eth6 ipv6addressup
    where ipv6address is the IP address of the interface.
  3. Add the VID.
    For example, type:
    # vconfig add eth6 5
    where eth6 is the interface, and 5 is the VID.
    Note - In Linux systems, you can use any single digit as the VID.
  4. Configure the i40e VLAN.
    For example, type:
    # ifconfig eth6.5 ipv6addressup
Related Information
