ok show-nets a) /niu@480/network@0 b) /pci@400/pci@2/pci@0/pci@c/network@0,3 c) /pci@400/pci@2/pci@0/pci@c/network@0,2 d) /pci@400/pci@2/pci@0/pci@c/network@0,1 e) /pci@400/pci@2/pci@0/pci@c/network@0 f) /pci@400/pci@2/pci@0/pci@a/network@0,1 g) /pci@400/pci@2/pci@0/pci@a/network@0 q) NO SELECTION Enter Selection, q to quit: q
These examples assume that /pci@400/pci@2/pci@0/pci@c/network@0 is a port on the adapter.
ok cd /pci@400/pci@2/pci@0/pci@c/network@0
ok .properties
The output should be similar to this:
vf-assigned-addresses c3060000 00000041 00810000 00000000 00010000
c3060003 00000041 00a10000 00000000 00004000
assigned-addresses c3060010 00000041 00000000 00000000 00800000
c306001c 00000041 00800000 00000000 00008000
82060030 00000000 01200000 00000000 00080000
vf-reg 43060000 00000000 00000000 00000000 00010000
43060003 00000000 00000000 00000000 00004000
reg 00060000 00000000 00000000 00000000 00000000
43060010 00000000 00000000 00000000 00800000
4306001c 00000000 00000000 00000000 00008000
02060030 00000000 00000000 00000000 00080000
local-mac-address 3c fd fe 9f 00 a0
version Oracle Quad 10Gb or Dual 40Gb Ethernet Adapter
FCode 3.4 1/29/2016
board-model 7096437
model 7111185/7111186
compatible pciex8086,1583.108e.7b1d.2
pciex8086,1583.2
pciex8086,1583
pciexclass,020000
pciexclass,0200
address-bits 00000030
max-frame-size
00002400
network-interface-type
ethernet
device_type network
name network
fcode-rom-offset 00056000
vf-stride 00000001
first-vf-offset 00000010
total-vfs 00000020
initial-vfs 00000020
#vfs 00000020
port-type PCIE-Endpoint
interrupts 00000001
cache-line-size 00000010
class-code 00020000
subsystem-id 00007b1d
subsystem-vendor-id 0000108e
revision-id 00000002
device-id 00001583
vendor-id 00008086
{0} ok
If you do not see the device listed, check that the adapter is properly seated. If necessary, reinstall the adapter.
ok device-end
