Go to main content
oracle home
Sun Network QDR InfiniBand Gateway Switch Product Notes for Firmware Version 2.2
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Sun Network QDR InfiniBand Gateway Switch ...
Updated: October 2019
Document Information
Using This Documentation
Product Documentation Library
Feedback
Late-Breaking Information
Features and Functionality Documented
Known Problems
General Information and Issues
Jumbo Frames
Subnet Manager
Snapshot Dataset Information
Software Information and Issues
Partition Configuration Consistency Checking
Infiniband Switch Power Supplies With Part Number 7351491 Require Firmware 2.2.9-3 or Later
IPMI 2.0 is Reenabled After Upgrading From Firmware 2.1 to 2.2
New ip Command
Syntax
New ifconfig Command
Syntax
Options
Management Ethernet Port Numbers Used in Firmware Version 2.2
Inactive FIPS Target
Main Board, Management Controller, and Chassis Serial Numbers
High Availability in Partitions
Email Alert Rules
Oracle Solaris EoIB Considerations After Upgrading to Firmware 2.2
Hardware Information and Issues
Reset Undervoltage Condition
Ethernet Support
Unusable Ports
Documentation Information and Issues
Correct Description of the create_ipoib Command
Correct Description of the smsubnetprotection Command
Autodisable Command
Syntax
Description
Upgrade and Downgrade Paths Supported
Firmware Update Guidelines
Determine Management Controller Type
disablegwport Command Connector Invalid
Replace a Gateway
Multiple Subnet Managers in a Single Fabric
Upgrading the Gateway Firmware
Acquire the Gateway Firmware Package (CLI)
Upgrade the Gateway Firmware (CLI)
Language:
English
October 2019
Provides late-breaking information about the gateway.
Feedback
Known Problems
Jumbo Frames
Subnet Manager
New ip Command
Syntax
Syntax
Options
Email Alert Rules
Ethernet Support
Unusable Ports
Autodisable Command
Syntax
Description
Replace a Gateway
