Replace a Gateway
This procedure briefly outlines the steps to replace a gateway within an
InfiniBand fabric. Refer to Gateway
Service, Gateway
Administration, and Gateway
Installation for more information. This procedure assumes that a
secret M_Key policy is in use and the fabric is partitioned.
Set the priority of the gateway to be removed to the lowest.
Wait for any handover to complete.
Create a backup of the gateway configuration for the gateway to be
removed.
Completely power off the gateway.
Remove the gateway from the fabric and management network.
Install and power on the replacement gateway, but do not connect it to the
fabric or the fabric's management network.
Configure the replacement gateway with the same host name, IP address, as
the gateway removed.
Restore the gateway configuration previously backed up.
Readout and store the SM priority from the restored gateway configuration
using setsmpriority list and then set the SM priority to
the lowest in the Infiniband Subnet.
Completely power off the replacement gateway.
Connect the replacement gateway to the fabric's management network and the
fabric.
Power on the replacement gateway.
Wait for any negotiation and propagation to complete.
Setup the smnodes list and fabric configuration file
for the replacement gateway, and ensure that the list and file are
consistent with other gateway and switch lists and files.
Perform a smpartition start and smpartition
commit from the master Subnet Manager.
Wait for the partition configuration to propagate to the replacement
gateway.
Perform a smsubnetprotection start and
smsubnetprotection commit from the master Subnet
Manager.
Wait for the secret M_Key policy to propagate to the replacement
gateway.
Set the priority of the replacement gateway to that originally of the
removed gateway.
